Question about Shuttle MV43N Motherboard
Bogdan sorry,my englisch is not good! i dont have out audio signal,please help me!thank YU verry mach
    President:
  • 2,351 Answers
Hi zlasav, there are a few things that must be checked before checking within the system. Please check your speakers by connecting them onto another system or notebook. (Make sure they function). If you are using windows XP any version, open control panel. Once opened than open the icon, "Sound and Audio Devices". The sound & audio properties window will open. Left click the "Audio tab". Under Default device: it should show something like "AC'97". Than left click the "Voice tab". Under default device: it should show the same, AC'97. If nothing is listed than there is either a problem with your sound device driver or the AC97 may not be enabled in your bios. To check the settings in your bios. Shut down the system. Then power up the system & press the F2 key every two seconds until the bios main menu opens. Please see page 50 in your manual. Turn to page 63 & 64 make sure your, Audio device is set to [Enabled].
Open control panel & open the System icon. System properties window will open. Click once on the hardware tab, than click on the device manager button. Device Manager window will open. Scroll down to, "Sound, video and game controller". Click the "+" sign to the left of Sound, video and game controller. (If it is not all ready opened). There may be a yellow explanation point shown there. If there is, you will need to reinstall the sound driver software. Do not use the Shuttle CD to install the audio software. Left click on this link which will open Shuttle's web site to the driver download site for your MV43N motherboard. http://eu.shuttle.com/archive/en/mv43n_faq.htm#download
Now create a folder on your desktop & name it AC97. Download the driver file named, (Audio Driver for MV43N (2155kB) & save it into the AC97 folder you created. The driver will be compressed & will need to be uncompressed into the AC97 folder. The compression software used by Shuttle is called Winzip. You can download Winzip for free at this site: http://www.download.com/WinZip/3000-2250_4-10003164.html Once Winzip is downloaded, install the program. Than uncompress the file, (Audio Driver for MV43N (2155kB), keeping it in the AC97 folder. Once that is completed it is time to reinstall the audio software from within windows device manager.
Instruction: How to install driver software from within device manager. Use the instructions above to open up device manager again.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you’re desktop folder AC97 & open it. Left click once on the folder named, Audio so it is high-lighted. Than click OK.
Windows will find the correct driver software & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio devices within the control panel. If this does not fix your sound issue, than the onboard sound chip is defective. The only other option is to buy & add a PCI sound card in to an opened PCI slot on your motherboard.
If you have any questions or trouble just post it here.
Good luck zlasav!
Please take your time.
Mike
Posted on Sep 13, 2008
Saab 9-5 radio replacement
Europarts .com columbus ohio very helpful with my 2000 turbo 93 radio pixels out bad easy fix after pullin unit out strips going tobboard dobthis quickly but not so long yu meltvthem back to board lightly with soldering iron press gently till they reseat to motherboard hot butter knife works to so yu can press flatter and control your heat so yu dont melt strips or make contact with anything else so no short outs all fixed pixels back!
May 30, 2014 | 1990 Saab 900 Hatchback
My Bosch Dishwasher das not drain water after washing is completed. The water level stays below door sealer. I did check it out filter on the bottom and everything simce ok but still dosn't work. Is there...
Sorry to read about your problem, I hope this helps you out.
you have done it all
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Bosch SHU9950 Dishwasher
I wont from englisch to dutch how i can doe it
If you are using U.S. Version Yahoo Messenger 10.0, You can easily change the language before you login.. You can download the U.S. Version from the below link.. http://messenger.yahoo.com/download/win/ To change the language, please refer to this graphical representation... f930032.jpg
and select the language, and sign in... Good luck...
May 09, 2010 | Yahoo Messenger
How do i tighten the chain on an electric royal einhell 1840/1?
Hello James;
Your saw is listed here and contians a link to "isc-gmbh" for an instruction manual. My German is a little weak.
http://www.einhell.com/englisch/englisch.aspx?file=gartentechnik
I think this will get you to a "Contact Us" page where you can make your request.
http://www.microsofttranslator.com/BV.aspx?ref=IE8Activity&a=http%3A%2F%2Fwww.isc-gmbh.info%2Findex.php%3FPHPSESSID%3D4848211954ba3bd3d5041a%26mainid%3D4%26subid%3D8
I must admit I am not familiar with your saw and many electrics are different. This is a very good manual for an electric and while it may not be exact is good guidance. Please obtain the correct OM for your saw, but this should work in the interim.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Garden
I installed windows XP and dont have sound software.
i have installd xp and i dont have sund driver ....hp paviliondv5000 sund driver....
Aug 17, 2009 | Packard Bell (030069) Sound Card
I want change the language in german (nokia6555b at&t)
you go to phone settings, language if german isnt there. the phone jst cant be changed. sorry for any inconvience
Jun 30, 2009 | AT&T Nokia 6555 Cell Phone - Black
Bad reguest
hi there,
first try to make an account in you tube to use in signing up.
but make it sure that all ask question are answered correctly and you never forgot to fill it up.
after that check your given e-mail tey will send you a confirmation just follow the instruction very carefully ok.
please don't forget to rate me..
thanks
Feb 17, 2009 | YouTube Videos
SOUND PROBLEM
Hi M8!
Try to reinstall the drivers for your soundcard, you can download them from the link bellow
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2669
If you find this helpfull for yu, dont forget to vote!
Good luck to you
Dec 11, 2008 | E-Mu 0404 Sound Card
Shuttle MV43N Motherboard Logo
141 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
