Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire front load won't tumble
I get only a low buzz when I turn it on. The light works, and the light goes out when I manipulate the closed-door button by hand. I don't see any burnt or loose wires (except two with a male end that seem to have nowhere to go).
Was working fine until couple days ago (guess things have to break sometime!).
TIA!
Enrique
  • enriqueG Sep 12, 2008
    Praise John McCain and put lipstick on his pig - it is fixed! This site educated me considerably, and led me to this site,http://appliancejunk.com/forums/index.ph... Together these sites educated me about start windings and normal run windings, as well as the troubleshooting tip of pushstarting the thing to see whether the dryer starts to run after getting an assist, which would indicate that the start winding, or the start capacitor (are those the same thing?) is or might be bad. Lo and behold, the troubleshoot was the fix! Pushed it, it started to go on its own, and the next time I hit start off it went.
    Thanks very much to all.
    Enrique
    Genius:
  • 1,122 Answers
Do the 2 wire go to the door switch?mike
Posted on Sep 12, 2008
Reason for door codes on a frigdaire front load dryer
Assuming door seal is good, make sure there is nothing "caught" under the seal that prevents the door from closing properly. Otherwise, look for anything else that would contribute to that issue. Possibly the door switch that turns on the interior light and acts as a safety for a door open situation may not be operating properly. See my "generic" tip for "buzzing" dryer issues.
Mar 03, 2015 | Frigidaire Affinity FAQE7011LW Electric...
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Affinity washer
I think that means faulty door electric lock
Dec 21, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLEQ642A Electric Dryer Logo
83 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
