Question about Compaq Presario M2000 Notebook
Presario m2000 no power
Hi
I saw couple of your post figured i ask for some help. My presario m2000 will not power on ...with or without battery doesnt matter its dead ..when i plug in the ac adapter the light doesnt even come on ...adapter works since i have another identical laptop ...any ideas what can i check? do need new mobo? hope not
let mw know
thanks
  • Matt Lumb
    Matt Lumb Dec 09, 2008
    Hi, I have the same problem. I think I am on the road to a solution:
    Would not start from battery or adapter (or with battery removed). Adapter giving good output. Disassembled it, traced power through from power board to mobo, OK. Found out that with it disassembled, and the HD plugged back in it started and ran normally. Upon reassembly, it ran OK for a few minutes then same fault. Removing one screw at a time showed it was one of the screws underneath the keyboard (left bottom of 4). When this screw is tightened, the laptop dies immediately. Note you must then disconnect all power (battery removed), release the screw and wait maybe 15 seconds before it will start again. This indicates to me that there is a resetable fuse component (multifuse / polyfuse / polyswitch) which is operating due to a short circuit made by tightening the screw. I am going to disassemble the laptop fully to see where the short is occuring and will report back if there is something conclusive that fixes it properly. Matt
The same EXACT this happend to me! i didnt know what to do so i just a new charger at dell.com
Posted on Sep 14, 2008
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
Hi.. I have a Compaq Presario M2000. How do I turn on the wireless. Or does it even have that. It has a wireless symbol but it's not lit up. Thanks..
Yes, it has wireless and blue tooth. Simply download the owner manual of their website. Here is a link
http://search-manual-online.com/compaq-presario-v5000-notebook-manual.html
Apr 26, 2010 | Compaq Presario M2000 Notebook
MY presario M2000 notebook will not power on.
how about the battery of the laptop, have you aleady check it? if you can find a working identical laptop like the one that try using the battery and see what happens if it will work or not, if it work then you have a battery problem and needs replacement
Nov 28, 2009 | Compaq Presario M2000 Notebook
Turn on a s/h presario m2000 and it asks for a password of which i dont know what do i do`
try pressing esc. two times.
Or type admin for username or admin for password. Or try password for password.
Jul 04, 2009 | Compaq Presario M2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Presario M2000
i need intel presario m2000
May 08, 2008 | Compaq Presario M2000 Notebook
M2000 compaq
Press F10 immediately after powering it up (before your OS boots) to allow you entry into the BIOS/CMOS configuration. Normally, there is a selection for setting every to default. Thereafter, Save & Exit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 17, 2008 | Compaq Presario M2000 Notebook
Compaq M2000 beeps twice
Try powering it on without the battery in (with the power plugged in). Are the results different?
Dec 06, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
