Pioneer plasma 50 inch tuner problem. unit shuts down, won't turn back on, display displays fault code e01, power button flashes red, sometimes it works, then the next day it does it again
    Genius:
  • 1,239 Answers
    • hi sir
    •  there may be a problem in the power section.. if it is in warrenty u trust them.. or there is a usefull manual just refer it : www.visualapex.com/​plasma/​Plasma_​details.asp?​chPartNumber=​TH-50PF9UK&​amp;​MFR=​Panasonic
      if any problem i am there to assist u ...
       thank u
Posted on Sep 12, 2008
  • 3,037 Answers
The power supply in the media box is usually the most likely culprit.
Dismantle the media box and remove the LARGE power supply board and check for dry solder joints. Where the heatsink is soldered onto the board the joints may be in a bad way. This is usually a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
Resolder the joints and you should be good to go. Whilst I can't guarantee that this is the definitive fix for this problem it seems to work for a while and is just a problem that many of these units have.
My Kawasaki zx6r 2009 keeps displaying f1 and with a flashing red light. The bike runs fine. Sometimes shuts off while warming up. how do I fix it?
it actually means fault indicator and doesn't deal solely with the fuel injection.
put the key in the ignition and turn it on, but don't start the bike. use the mode button to go to the odometer display, then hold the mode button down for 2 seconds. the code should be displayed.
come back when you have the code
Apr 18, 2015 | kawasaki Motorcycles
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
May 23, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
BLUE POWER LIGHT
Jan 26, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Screen frozen
Dec 29, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
