Dvd/vcr unit does not respond to Start-up key on remote. Nothing shows on the TV Can't get to "general setting"
  • lma1227 Sep 12, 2008
    It is a brand new Magnavox unit and remote. When I press the setup buttom, the displat reads "E1" indicating where I have plugged in the wires ( rear vs front=E2). And that's all that happens in startup. Thanks for trying.
  • 37 Answers
The remote buttons are probably dirty (coke or coffee). If you feel lucky you may be able to open the remote and clean the rubber pads and the copper traces on the circuit board with alcohol. Usually there are only one or two screws holding the remote together. One may be in the battery compartment and sometimes they hide one under a sticker on the back. Pay close attention when you take it apart because parts (buttons/springs) may fall out. Good Luck!
nssms
Posted on Sep 12, 2008
  • nssms Sep 15, 2008
    You can try fresh batteries (not the one's that it came with). Most likely the whole thing is bad and you should take it back to the store and trade it in on a good one.
    nssms
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
OK?
Nov 24, 2007 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
My remote control has broken.
I would check out the Harmony 510 remote control. It may be a little pricey but it is the best universal remote on the market for the money. It also allows you to control your DVD unit as well as your TV without the requirement of selecting which one. Harmony remotes are activity based in the you pick what you want to do such as “Watch TV”, “Watch DVD” , “Watch VCR” etc.. Then It turns the appropriate units on and then sets them to the correct input. Makes it real easy once set up. Another advantage is the IR codes are stored on line and constantly updated so new products and codes can be added.
Check it out:
http://www.amazon.com/Logitech-Harmony-Advanced-Universal-Control/dp/B001F51G1Q/ref=sr_1_10?ie=UTF8&s=electronics&qid=1270172488&sr=8-10
Apr 02, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
Rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
Feb 22, 2009 | RCA 3-Device Universal Remote with...
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
