Question about Sony Cyber-Shot DSC-W7 Digital Camera
Camera turned on and shuts off
Fully charged batteries, yet it shows no battery energy left and turns off immediately. I've checked the batteries and they are charged.
  • nickbanton Dec 02, 2008
    My W7 shuts off after only a few minutes even with fully charged NiMH batteries. The battery indicator shows that the batters are not charged; to be more precise the battery indicator shows the fully charged batteries as having low to no charge.
  • Sony Master
  • 586 Answers
This problem related to lens assembly but not the battery.The zoom optical motor shows malfunctioning and you have to replace it.For this contact nearest SONY SERVICE CENTER
I have change many optical lens assy in this symptoms.
Thanks & dont forget to rate.
Posted on Nov 01, 2008
I turn the camera on and it immediately shuts off.
Check battery condition - if low on charge camera will do this. If battery is fully charged then you have an issue with the electronics.
Sep 25, 2015 | Cameras
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Batteries are charged, flash doesn't go off and camera shuts down, ready light blinks amber, then read and then shuts down
Since the flash requires lots of energy it sounds like you have a battery problem. 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 24, 2010 | Kodak EasyShare C340 Digital Camera
My camera shuts off immediately after turning it on, and the battery is fully charged. what's the problem?
Take off the battery and the memory card
Try to wipe the metal contacts on battery with a cloth
Try to put back on to the camera with out the memory card
Try to turn it on
If the camera still have the problem
Try to take the battery out
Try to plug the charger directly on to the wall outlet then plug it in the camera with out the battery
Try to turn the camera on
If the camera has the same issue
Call the manufacturer
Aug 11, 2009 | Kodak EasyShare M1033 Digital Camera
My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Jul 15, 2009 | Kodak EASYSHARE V1253 Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
191 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
