Question about Matrox 128 MB G450 Quad Graphic Card
1 monitor is red - 1 is green
I currently have 3 monitors hooked up to my system. Onboard video (NVidia 6150) displays all colors properly on monitor 1, but the 2 monitors that I currently have hooked up to the 450G (both hooked up to the top video output to a 2 way DVI splitter and then through dvi to vga adapters) are showing up in some funky colors. My desktop expanded to monitors 2 and 3 just fine, but monitor 2 is red tinted and mionitor 3 is green tinted. I have th emost current driver form the Matros site. Any tips?
  • Noidios Sep 13, 2008
    This is a video card capable of handling 4 monitors with independant displays - no cloning involved.
Ya i am not to good with mulitaple displays sory.
Posted on Sep 13, 2008
  • 39 Answers
Its because when you start putting to many moniter spliters the color data gets lost in the link.
Hello, my video card is nvidia geforce 6150 le and the red color is gone, thank you for your help.
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
Aug 16, 2011 | HP Compaq Presario SR2020NX PC Desktop
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Apr 18, 2011 | Dell Dimension 2400 PC Desktop
NVIDIA GeForce 6150 SE video card has taken over
check the monitor settings, then check the operating system settings e.g. windows if ok
got the the monitor drivers in the Control Panel and check that it was installed properly if yes, you can stall update the drivers to make sure.
Dec 31, 2009 | eMachines ET1161-05 PC Desktop
Monitor will not come on
Try to remove the wire connecting from the monitor to motherboard if there was a display in the monitor then no problem with your monitor. Try to check the battery in motherboard.
Aug 25, 2009 | HP Hewlett Packard Pavilion Slimline...
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
My Hp mx70 monitor Will rendor the color green as black
Dear Killkerson,
As i understand from the situation, Please do the following:
1. First confirm that the problem is with the monitor. You can do this by trying this monitor on any other CPU. If the monitor behaves Fine, the problem is with the Video Card (Nvidia in your case). If the monitor behaves the same way on other CPU as well, i recommend taking it to nearest service centre. Please Do Not open monitors yourself (Some CRT's may have a possiblity of electrocuting people because they can store a charge upto 25000 Volts in Capacitors). Better get that serviced by authorised people if it doesnt work on any other computer.
2. If the above monitor just works fine on any other machine, probably the problem lies with Video card adjustment.
Please Right click on an empty place on your desktop and click on Nvidia Control Panel. (or you can go to control panel and try to run the same from there).
you will see that Nvidia's video card utility will open. On the left hand side, you will find (depending on the model) 3 basic options.
1. 3D settings
2. Display
3. Video & television
Expand the Display option and select "Adjust desktop color settings" on the extreme right on the top, you will find an option of "Restore Defaults." Click on that and close the utility. Check if that has resolved the problem.
If not, please try resetting all the options back to Default on the Video control Panel one by one.
I am hopeful that it will solve your problem.
Feel free to contact me if it doesn't solve. I will try to help you till it does.
Have a wonderful day ahead.
Regards,
Techno-Geek.
Apr 23, 2009 | HP Pavilion MX70 17" CRT Monitor
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
I want dual monitor for my PC
simply install another video card or get a card that has two outputs no pc will work with more than two video cards but the best setup is 1 on main board and one in the agp slot . or 1pci and 1 agp then enable them in your display settings :)
May 28, 2008 | Computers & Internet
Matrox 128 MB G450 Quad Graphic Card Logo
149 people viewed this question
Top Matrox Computers & Internet Experts
David Payne
David Payne
Are you a Matrox Computer and Internet Expert? Answer questions, earn points and help others
