Question about Bush 1433GRN2 14" TV
My Tv won't turn on
It is only a year old. I have changed the fuse in the plug and checked that everything is plugged in and switched on. But it just won't turn on. Can anyone help?
    President:
  • 3,130 Answers
It probably has a power supply problem or a sweep supply problem?? Your gonna need a schematic diagram to trouble shoot and find out whats bad. if you cant troubleshoot electronics by using a meter or scope then I would contact the manufactuer listed in the owners manuel.. Good Luck
Posted on Apr 30, 2006
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
I have1994 sl1 Saturn its been sitting for like five years and will not start how do i get it running again. I Chang the battery. An the spark. Plugs an wires and i have drained. The old gas out an...
Ok ou changed the battery, the spark plugs and spark plug wire and drained the old gas out. You could also drain the fuel line, so that any gunk in it. Did you change the oil and the transmission fluid? Did you drain the radiator and flush it out before refilling it with water an anti-freeze? You need to find where the fuses are and change them all, because it is difficult to tell if a fuse is bad or not. The fuses are very old, and they can cause the car not to start. Do you have lights? Have you checked your alternator? If it is not working, the battery will drain and the car won't start. It's a cheap fix. Have you checked your hoses and clamps? If the problem is that it is not starting when you turn the key, the starter could be bad. You can test this by hot-wiring it (I'm sure you can find instructions online). Also, check your belts and make sure they are in good condition. If it has been sitting that long, the belts are probably dried out. They are not hard to change, or very expensive, if you do it yourself, but if they aren't too bad you can get some belt conditioner that will help. If I think of anything else, I will let you know.
Jun 10, 2012 | Cars & Trucks
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
Truck turns over but wont start
check for spark, check for fuel, check fuses and relays, replace old oil,old fuel
Sep 20, 2009 | 1997 Chevrolet S-10 Pickup
Televison & Video Logo
126 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
