-   I'm trying to scan the photo to the computer but notting is happening, it takes the photo and nothing happen what's the problem, I just want the photo into the computer so i can save the photo. -   Guest
Nov 18, 2008
-   Same issue trying to copy or to fax.-   Russ0630
Nov 17, 2008
-   When I attempt to use the copy function, the display first says warming up, then displays scanner failer " turn power off then on.........."-   jasutyak
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink....
(More)
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink. How can I select "print in black only?"
