Question about Craftsman 25cc Gas Line Trimmer
Remove head I can't seem to get the head off so I can put new line in. Please help!
  • 2 more comments
  • lentaylor Sep 16, 2008
    i cant figure out how to get the head off to add line
  • Anonymous Oct 05, 2008
    how to take weed wacker apart
  • privatepolic Oct 13, 2008
    I cant seem to get the head off to add string what do i do ? please help ?
  • clo2010 Apr 10, 2009
    /im having trouble pullig my starter string on my craftman gas weedtrimmer model #358.79250
2 Suggested Answers
  • 38 Answers
SOURCE: remove head to replace line
turn unit upside down so you are looking @ the underside of the spool. On the side of the spool should be a hole which you insert a rod to keep the spool housing from turning on the shaft. Turn and head will come right off.
Posted on Sep 12, 2008
Epson stylus r240
please clean print head and if issue still than remove print head and put in print head cleaner for 24 hours. after inject liquid in print head and than refax print head. if issue is still than replace print head.
Jul 09, 2013 | Epson Office Equipment & Supplies
I have a Epson stylus the print has white lines on the letters as well as the photos. i have cleaned done head cleaning several times alignment no use it still prints the same
It seems that the print head is clogged.
You can choose to live with it by print at slowest speed (best photo or things like that) Or you may try to fix, however, it requires some skills.
A. USING ALCOHOL
1. Check if what print head was clogged: Print a test page. 2. Look at the test page, identify incomplete lines. what are there colors? For instant, blue line: clogged on blue head 3. Remove the ink tanks, and pump alcohol through the clogged print head 4. Do head cleaning to see if it works
If it does not work, try B method. Please only do this if you have experience on disassemble a printer, or you have nothing to lose, because incorrect handling parts from printers will kill it forever.
B. DIPPING THE PRINT HEAD IN BOILING WATER
1. Remove the ink tanks,. 2. Remove all the cables connect to cartridge 3. Remove the cartridge 4. Boil some pure water ( Aquafina of Pepsi is the best) until small bubbles appear 5. Dip the head of cartridge ONLY in boiling water for 2 minutes. 6. Put all things together.
Mar 26, 2011 | Office Equipment & Supplies
I am trying to remove and reinstall the cylinder head of my 1994 S 10 pickup truck. I have removed the nuts and bolts holding the intake and exhaust manifolds to the head but I am having some dificulty in...
Leave the exhaust manifold attached and just push it away. Remove the head bolts and make sure all vacuum lines and fuel lines and water lines are disconnected. Make sure you have the head resurfaced before reinstalling and buy new head bolts. Remember to torque the head bolts to spec. But it seems to me like you pretty much got the hang of it.
Jan 30, 2011 | 1994 Chevrolet S-10
Hi, my 2001 Pontiac Grand am SE 4 cylinder 2.4 engine has been starting very "rough" as it runs however it eventually fixes itself. Also my coolant has been "disapearing" i keep having to refill the...
Probably needs cylinder head and gasket, for that rice. Cylinder head gasket is around $1700-1800.00.
Fuel pressure regulator is not too difficult, you have to disconnect fuel line where it goes into fuel rail. and remove regulator, then install new regulator and put fuel line back in. You will loose some fuel, so loosen fuel line slowly, and put a rag around it to keep if from spraying out too badly.
Hope this helps.
Mar 02, 2010 | 2001 Pontiac Grand Am SE
1979 chevy step van 350 new fuel pump rebuilt carburetor wont sta
remove the fuel line from the carb, put it into a bottle, crank the engine, If the bottle has fuel in it the fuel pump is working properly, if not, check the filter, and the fuel lines to the tank!!!
Nov 02, 2009 | 1979 Chevrolet C/K 3500
I have replaced the line spool with a new one and it will not run
hey mate, the best thing to do would be try eliminate sections if the head does not spin remove it see if the arbor that the head connects spins with the head removed, if it still does not spin remove remove your drive shaft and check if motor actually spins some of these contain sheer pins to prevent damage to the motor, I would highly reccomend this be done by a professional as there is moving parts and electric motor involved... hope this helps
Brad:)
Sep 20, 2009 | Black & Decker 14" Grass Hog Xp...
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage.
7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place.
8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Remove head to replace line
Sep 12, 2008 | Craftsman 25cc Gas Line Trimmer
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Craftsman 25cc Gas Line Trimmer Logo
521 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
