Question about GPX KCL8806DT 7 in. Portable Television
No sound gpx klc8806dt
The unit was out of use for 6months and was working 100% when it was stored in clean dry area. Now it powers up, tv functions, radio tuner works, remote works, all funtions except sound. When changing modes, or powering up, I can hear a faint hum thru the speakers. The remote switchs from mute to sound, and the speaker symbol is displayed on display window. Any body got a clue??? Thank You!
    Problem Solver:
  • 10 Answers
Hello, i have fixed a few of these units, Mainly the problem is, is the crappy design inside, take out all of the screws from the bottom of the unit, be careful when pulling the top cover off cause the battery unit on the side is detachable and could be stuck and u can rip the wires off the system board. now you will see the 2 speakers, take a razor blade and carefully cut away the glue that holds the speakers in, and there may be little white plates with 2 screws that hold the speaker down also. Now take the speakers out and test them on a home entertainment center or a cd player that has red and black connectors for speakers in the back. See if they work first, if they do carefully reconnect the speakers to the motherboard and reseat the connectors back in with ease. try the unit again. if it doesnt work check the solder joints where the connectors attach to the motherboard, sometimes they will come loose. From my expierence with these units is they tend to jam the speakers inside so tight that they eventually stop working, so be sure to only use the connectors to hold them in.
Posted on Mar 04, 2009
What converter box do I need for GPX TVP2 5" portable tv?
They all work. If in strong signal area get inexpensive unit.
Feb 04, 2016 | GPX Tvp2- Bk & Wh Tv & Am/fm Radio Battery...
Power button stuck on and all other buttons unusable
The best solution is to clean the power button socket area.
TV tuner cleaner would be a good start with a razor to clean the edges.... 100% isopropyl alcohol. * Make sure you unplug the printer prior to any cleaning and allow at least 1 hour for the cleaner to dry.
Nov 30, 2013 | Kodak Office Hero 6.1
My epson LX 300+II always turn on, if u hit the turn off button, still turn on. pls help me this one.
Nov 30, 2013 | Epson LX Office Equipment & Supplies
Hello I have a rotel RSX 1056 witch I used once six years ago for two months . I lhavent used it since then , and now I decided to hook it back up and I have no audio . It turns on but when I set a radio...
If you stored it in an area with high moisture content it is probably corroded at most of the contact switches. Capacitors also hate moisture, especially paper capacitors! The tuner is also probably oxidized inside. Now is the time to be brave and pull it apart, but first PULL OUT THE PLUG from the wall. Have at it with electric parts cleaner spray and clean, dry compressed air. If you believe that just because you stored it in your house, there was no moisture, think again! Radios like cars do not do well in storage unless you take precautions to protect them!
Jan 02, 2013 | Rotel Rsx-1056 Receiver
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
No picture just sound
Have you tried cleaning the video head with Servisol Video 40? You could use a cleaning tape, but I think it's better to whip off the top and give all surfaces the tape touches a good clean. You can use cotton buds to reach hard to get areas. Leave to dry before trying a tape. This should work as long as it will pick up a normal TV picture. If the VCR does not, this will be waste of time as the tuner unit is faulty.
Jun 19, 2011 | Samsung SSC-960 VHS VCR
My 32lg30 was shorted out during a lightining strike in a storm the other night. plug it in, and press power, and now nothing works. reset button or replaceable internal fuse? I am tech savvy so I can do...
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the entire power supply board, click this LINK.
Hope I helped you.
Thanks for using fixya.
Jdvillanueva
Jun 04, 2011 | LG 32LG30 32 in. LCD HDTV
I have a Garmin Nuvi 650 with an unresponsive screen...can anything be done? Thanks
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
    May 20, 2011 | Garmin Nuvi 660 GPS Receiver
    I have garmin nuvi 680 not responde el touch escring
    May 15, 2011 | Garmin Nuvi 660 GPS Receiver
    I have Garmin Nuvi 265W. When I plug my car charge to charge up the battery and use the Navi at the same time, I only get the "GARMIN" screen connected the computer but can't use Navi function...
    Try a hard reset,the Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
    1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
    2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
    3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
    Perform the Hard Reset:
    *Note that this will clear all user selected settings on the unit
    1. Power the unit off.
    2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
    3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
    4. Press "yes" and the unit will reboot. This resets all your location settings and user preferences
    Then make sure the unit is fully charged,then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
    May 01, 2011 | Garmin Nuvi 265W GPS Receiver
    GPX KCL8806DT 7 in. Portable Television Logo
    321 people viewed this question
    Top GPX Televison & Video Experts
    Bill T
    Level 1 Expert
    Jaime Hernandez
    Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
