Refrigerators Logo
Anonymous Posted on Sep 04, 2011
Amana bx 52 ive refrigirator freezer and cooler part rubber sealer.where can i get one?
  • Anonymous Sep 08, 2011
    Hi.I received your solution but didn't find my part.sorry.please refund me.
Mike Cairns
Level 3:
  • Master 3,054 Answers
  • Posted on Sep 04, 2011
Mike Cairns
Master
Level 3:
Answers
3054
Questions
0
Helped
850909
Points
6358
I will try and help you here where to get a new rubber sealer for your Amana. I don't have your model or part number which you will need when you go to this sight. All you have to do is type in your model or part number in this link of amana sight I will give you, but sense this is a runner sealer issue, i would use there web site phone number, might be easier that number is 1-888-895-1535 and here is the web address to copy and paste the link in your browser. http://www.partselect.com I hope this helps and I have used them before, they are a good site and fast shipping,
Thank You So Much, and Have a Safe Holiday Weekend. Mike from Fixya,
  • Mike Cairns
    Mike Cairns Sep 08, 2011
    Hello Sir,
    You give up to easy, lets see if we can solve this. Did you call Amana? and if you did, and they could not help you, that is ok. There is lots of other things we can do to solve this problem. This is actually not to hard of a problem to solve and there is a lot of other things we can do to solve this. After all all you need is a rubber seal around freezer and cooler. What you have to do is be inventive, and that is what I am, that is why I am classified as a expert trouble shooter. Now we have determined of course what is wrong, not the fix is several options. Number one if you have called the place I told you, and they said they don't have one and could not steer you where to get one, then we go to plan B. Plan B is contacting a local appliance repair shop, they have hundreds of old fridges that have come in, that compressor has gone out, and they part them out, this includes rubber seals. There are hundreds of fridge and freezers your size that even different brand fridge and freezer the rubber seal will fit. The rubber seal, is just as you know a piece of rubber that goes around door opening, and can be cut with regular cutters to size. Also appliance repair stores, you can walk in there, and they even have this stuff that comes in rolls, that you measure your fridge and freezer and then cut to size and put it on. It is real simple. You DO NOT have to pay that over price from the manufacturer. Just hit up your local appliance store in your area, and most likely they can get you the rubber seal. Its not brain surgery, it is a simple seal that goes around opening, and make some calls in your area, mostly concentrate on used appliance and parts stores and appliance repair shops. Also, if you call a fridge or freezer local appliance mobile guy in your area they might have access to the rubber seal, have a roll on them, or get it for you. No, your not going to pay them to put it on or service call, your just going to call local appliance repair guys to pick there brain to get your rubber seal, and they could even tell you what appliance store has it, if they don't. Like I said this is real simple with a few calls in your local area. Thanks Mike
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
The freezer maintains the temperature, but the refrigirator shows 47 degrees irrespective of the setting.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2answers
Amana refrigirator bottom freezer moderl ARB 2214CW it leacks water on the bottom onto the floor it pudles in small amounts all the time at first I thought I spilled somthing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Top refrigirator not working, but bottom freezer working well.no solution even after replacement electronic control board
the main electornic control does not contorl the top tempt but the dampner does . there is for some model a newer style. thes are motor driven and some work well/ there is a update kit . yous mmay hase it but can not tell you i would have to see machine .... but i would say the dampner control is problem .. mm
3helpful
2answers
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
2answers
I have a leak of my tranny fluid and I think its from my transmission cooling lines,radiator or the cooler. Should I install an auxilary cooler for the transmission ?
Most cooler manufactures and automobile manufactures information we have read, recommends installing the coolers In-Series with the factory radiator cooler for maxium cooling efficiency.
If you must bypass the radiator because the cooler tube is leaking or for other reasons, be sure to increase the size cooler you install by 1 to 2 sizes.
It is not necessary but will help in the long run. Expecially if you are towing or do alot of driving.
Amana DRB2101Aw1
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
yhffg
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
