Question about Kenmore 23822 Top Load Washer
Tub will not fill with water
When I start my kenmore Washing Maching Model number 23822, the water runs fine from the sourcse, but drains immediately out. I inspected the tab on the lid and it seems to be working properly. Sometimes, it works when I run with warm/warm. But if I use any other type of water temp, water runs constantly, but does not fill nor does it progress to the washing cycle. (aggitation.) I recently added a pvc line from the black drain hose off the back of the unit to a direct drain. Could this be the problem? Any suggestions would be greatly appreciated. I have come home after a long day of work after running the maching in the morning, only to find that it has just been running water through it all day. My hot water heating bills are enormous because of this. Thanks
  • Ted Sammons Apr 30, 2006
    After reading through the rest of the solutions I found my answer. The drain hose must be at least 34 inches off the ground.
    So in the immortal words of Gilda Ranor's Emily Litella......
    Nevermind.
    Thanks!
    President:
  • 3,130 Answers
LOL!!!I was gonna suggest that you check the height of the hose as I've done the exact thing in the past letting that water run all day is expensive cause here in my area they charge you more to get rid of the waist water then they do for the clean water. Go Figure?? Any who its great you got back to us. Thanks again!
Posted on Apr 30, 2006
  • 38 Answers
That's Great Man. Thank you for letting us know!
When hot water goes in tub waster makes norris kenmore waster top lead model 110 serial # c 80207234
Try adjusting the water tap for the hot water. Open or close a little while it is filling up.
Jan 23, 2011 | Kenmore 23822 Top Load Washer
My kenmore washer 70 series immediately empties when I run water into it what is the problem? I do not have how water so I am trying to run cold water into just the cold intake and have tried running cold...
This sounds like the water is siphoning from the tub. Raise or loop your drain hose up (at the back of your machine) higher than the highest water level of the machine
Jul 09, 2010 | Kenmore Washing Machines
Drain standpipe overlfows on eshausting water
The pipe is clogged and may need to be replaced or cleaned out. Over time the pipe will get a build up of dirt and soap that you can't get out.
May 19, 2009 | Kenmore 23822 Top Load Washer
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washer Tub Fills With Water When Washer is Not On
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Jan 20, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 23822 Top Load Washer Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
