I have a kenmore he4t model 11045081401 wahingmachine that displays a f11 error code
That the ccu board you need a tech to get that fix
Posted on Sep 12, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My kenmore elite smartwash/he4t
    The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
    Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
    Kenmore he4t washer codes
    The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
    1. Select the "Drain/Spin" cycle.
    2. Select No Spin.
    3. Press the "Prewash" options and hold this button for 5 seconds.
    • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
    • After those 4 seconds the display switches automatically back to the selection mode
    NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
    Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Error code F11
    F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
    http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/1059575
    Nov 25, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Water is in the bottom of the washer after a day
    are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
    Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Washer stops with F11 code; door won't open
    F-11 ERROR CODE MEANS :
    Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    TO RESOLVE THE PROBLEM:
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check the Drive system for any worn or failed components
    • Check MCU
    • Check CCU
    • Check Motor
    May 05, 2009 | Washing Machines
    Kenmore elite error code
    possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
    Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
    He4t F0, F11 codes
    f11 is a communication error, assuming it was used in one home and now moved to another. i would remove top of unit and check wiring(especially leading to latch assy. that tub was probably banging around quite abit on the move(assuming shipping brackets werent put back in.) def chack all wiring first
    Feb 23, 2008 | Kenmore Elite HE4 Electric Dryer
    Washing Machines Logo
    229 people viewed this question
    Top Washing Machines Experts
