Question about Fahrenheat Electric Convector Baseboard Heater, 3'
How do I wire up a F2544 baseboard heater with 220 wire?
I recentley installed new f2544 heaters with double pol therms all new.i have 220 wire.{1red,1blk,1white,1 bare ground.} where do i connect the white whire? i have double breaker ,red and blcak conected to breaker. white and bare at normal spots in breaker box..in the heater itself where do these four whires go?i know where the bare ground goes..can anyone please help i have kids and its getting cold here.
  • 1 more comment
  • searcher04 Oct 21, 2008
    I have the smae baseboard heater and fta2a init-mount thermostat. i have 220 wire, white, black and bare wires. the black and white wires i attached to the positive in the breaker box and the bare to ground.
    i connected the bare wire to bare wire on heater and the white wire to red wires on the thermostat, and black wires the black wire on the thermostat. on the other side of the thermostat i connected the black wire to the black on the heater and the red to red on the heater. and turned the thermostat to the off. when i turn on the breaker in the breaker box it instantly trips (dead ground).. what am i doing wrong ??
  • POLIMENI9 Dec 03, 2008
    IF THERE IS ONLY BLACK AND RED ON THE BASEBOARD HEATER PLUS THE BARE GROUND ATTACHED TO THE BB HEATER, IS IT RIGHT TO CONNECT BOTH POS. CURRENT TO THERMOSTAT CAP OFF THE (NEUTRAL) WHITE, BARE GROUND TO BARE GROUND THATS ATTACHED TO THE BB HEATER
  • camaro22 Dec 17, 2008
    I have the same problem, the circuit breaker trips when the thermostat is turned on. Wiring the same as described. I am trying a single pole next.
  • 3 Answers
On a 220 volt systen for heating you only use 2 wires blk and red of 12 gauge size. For your question the white you can coil it up in the box and marrette the end then tape it, because you don't need it because there is no neutral in that system. Make it safe.Thank you.
Posted on Nov 29, 2009
In a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Posted on Sep 26, 2008
How big of an area does a farenheat F2544 heat?
That isn't a simple answer.
Sizing of heaters is done by calculating the heat lost over the coldest month of the year which is dependent on the build specs of your home and how cold it gets where you live. This is normaly done by engineers with expensive software.
Jun 06, 2010 | Heating & Cooling
The thermostat on my electric baseboard heater has a red and black wire out the top and the same on the bottom. The electrician ran the power wire from the box to both red wires, one on top and one on...
If is 120 volt heater.The thermo can use 220 or 110 volt.The elec is only using the 110v half/side of therm.Should be ok.Does it work?OK to leave blacks unused.
Mar 16, 2010 | Fahrenheat Electric Hydronic Baseboard...
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
Farenheat baseboard heater F2544
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Oct 20, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring a Fahrenheat model F2544 (1000 Watt 240Volt) Unit
There should be a wiring compartment at one of the ends of the heater 1/4 inch bolt holding the compartment shut. the link below will show you generally what it looks like rate me FIXYA! if this works.Good Luck.Oh yeah If I misinterpreted your question leave me a comment.
http://www.marleymeh.com/develop/prod_pdf/2500wiring.pdf
Nov 18, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
643 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
