Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Turn on and off
I have a d52w20 rca and the last few times i've turned the tv on it would have sound for about a second and turn off then it would turn on with no sound then turn off again any ideas thanks dawg
  • 1 more comment
  • Anonymous Jan 19, 2008
    Hi my name is Ryan. I have a 52" rca TV, the power will come on for about 5to10 sec and the screen is black, no picter no sound, then it will turn off, it dose this 4 or 5 times then just dosen't do anything.
  • bobbyr112008 Mar 14, 2008
    i have the exact same problem, i just need to know what board goes bad on the TV. if anyone has some insite on this it would help me greatly. you can e-mail me at bobbyr112002@hotmail.com
  • ulgyguy May 21, 2008
    I have a 52in RCA.When I turn it on the buttom comes on and off 3 times but no picture or sound. Sometime it takes a whole day of turning on and on to get it to work.
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Replace the sweep/ power supply module Good luck
Posted on Apr 30, 2006
I have a 52 inch rca D52w136D and it wont stay on it goes on and off what can i do to fix this
Posted on Dec 26, 2008
RCA = Repair Coverage Advised
Posted on Aug 30, 2008
I have a projection Rca tv with ctc 169 chassis.works but when its turned off you have to turn on for 30 to 45 min then it will come on and play all day.I believe its a cap anyone have any ideas which ones i need to check? thanks i will check this tv next week.
Posted on May 22, 2008
Hi i have a D52W25
the tv turn itself on and the channel turn itself too
Posted on Dec 31, 2007
    Genius:
  • 1,030 Answers
If the idicator light flashes this indicates a processor shutdown. first thing a customer can do is uplug for 30 min and try again. This never works i must admit but it eliminate the processor lockup chance. Now if it still does this then you have a problem the processor has detected a cuircit failure and shut the set down for safety. This also tells you it not a "FUSE" since the procesor is getting power. The processor generates a error log that can be read by a technician and a computer. other than that all i can offer is check for loose connection and if you have any technician experence alway check horizontal output transitor. BE CAREFULL TELEVISION GENERATED DANGEROUS AND POTETIAL LETHAL VOLTAGES
Posted on Dec 28, 2007
    President:
  • 3,130 Answers
Sworry man we dont replace modules in these sets we repair them like techs do to componet level! and yes if your not a tech dont try to repir a tv set as you can get hurt.
Posted on May 25, 2006
    Problem Solver:
  • 12 Answers
THIS COULD HAVE A DIRTY OR BAD RELAY AS WELL. BUT DEF. TAKE TO A REPAIR SHOP
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV not switching on and staying on.
Power board inverter is dead.
Buy a new one the web. repair it ur self Or hire
repair man part & labor $575.
Aug 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
391 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
