Question about Tappan Kitchen Ranges
Stove is reading F3 and beeping - Tappan Kitchen Ranges
  • jaime_22 Dec 31, 2008
    my oven is lock and the door is open and when i turn it on it beeps and read f3
  • Anonymous Mar 09, 2009
    my oven is beeping F3
  • 750 Answers
Peace tete1,
At your service!
You say your stove is reading F3 and beeping?
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT.
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You
Thank You
Posted on Sep 12, 2008
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ... > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ... > Manage My Life > Questions
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it '"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
My gas stove beeps and displays F3 what is is a kenmore 970-568212
This range was made by Frigidaire for Kenmore. Thus the F3 error could mean a problem with the temperature sensor, the EOC (electronic oven control) or the wiring between the two. You'll need to get to the back of the range and check the resistance at the sensor. In a ~70 degree F environment, the sensor should have a resistance of ~1100 Ohms. (The sensor is connected to the EOC by a pair of violet wires.) Make sure to rule out a problem with the wires, if the resistance tests out of specifications.
If the sensor gives the correct resistance and the wires are fine, replace the EOC. Please check that you have given the full model number, I can't find this model anywhere at Sears Parts Direct or elsewhere.
If the stove is under warranty, contact Sears for repairs. I hope this helps.
Aug 29, 2015 | Kenmore Sears Stove Grate Replacement Gas...
F3 on stove. Can't turn off
Hi Marie -
Since you didn't mention the brand and model of your stove - I can only offer general help. The first thing I recommend is that you shut off the power to the stove at the circuit breaker panel. It should be a double-wide 40 or 50 amp circuit breaker. Move the handle to the OFF position and leave it there for 30 seconds or so. Then return the handle to the ON position again. Doing this should "erase" the memory of the stove and reset the electronics. If the problem is not longer an issue - the F3 code should be gone. If it returns, we'll have to do more. That will require knowing the name of stove's manufacturer and model number. Let me know how you make out and if you need more help - provide the info requested and I'll see what else I can do. Good luck!
Mar 18, 2014 |
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more: Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
Jan 24, 2012 | Maytag Ovens
I have a maytag oven with f1 and f3 codes what
F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I'm getting a F3 Code and beepingfrom my gas stove/oven.
F3 means open ven temperature circuit you will likely need to replace the oven sensor.
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
195 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
