Require power board to suit Centrex Model# CTPL50H5 or information on what would cause the TV to remain on standby Any help would be appreciated Many Thanks Reply to ajpills@hotmail.com
  • 2,322 Answers
My search came up with a DLP manufactured by LG/Zenith. If you have the user's manual check the troubleshooting section to check for a lamp failure if the TV is not turning ON.
Let me know if you require further assistance.
Posted on Sep 12, 2008
  • 1,183 Answers
HI,
Could you give us the exact manufacturer and model number for the projection TV
Thanks
proton
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
The tv has power but the standy by button is flasshing and we are getting no picture
Flashing standby light is error sign that means TV got problem in its circuits and requires repair.
Model and brand info will help to find out details of flashing error code and please also count how many times standby light blinking.
Aug 12, 2009 | Televison & Video
Ilo tv model lct27ha36 does not go from standby to on
Are you doing this thru your remote? Did you try to manually turn it on thru the button of your tv?
Aug 01, 2009 | Televison & Video
Tv turning on and off, not a power supply problem, maybe tv seeing a fault trys to switch to standby
Most likely cause is bad filters on the main board. This is common problem and will require the main board to be replaced.
Jan 18, 2009 | Televison & Video
Specification for TV
Are you looking for the user manual or the service manual? Let me know I should be able to locate either one of them.
Mar 13, 2008 | Televison & Video
Centrex plasma tv model ctpl42s5
Centrex plasma tv model ctpl42s5 same problem wont turn on have extended warranty, what can we do.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
