Question about Sony KP-53V80 53" Rear Projection Television
Screen shows green and lines and shuts off
My screen comes on, shows me green and white background will lines that horizontal and then shuts off. My red light stays on permanatly and will not turn on till i unplug it and plug it back in.
    President:
  • 3,130 Answers
If the screen gets really bright then shuts off its going into protection shutdown. Could be a bad or shorted green tube. Or your missing the drive voltage from the sweep supply that suppys b+ to the screen transistors or the High voltage block. This is a hard thing to track down without monitoring points in the curcuit. If you troubleshot electronics i would start with measureing the screen voltage first. If thats ok then i would then monitor the HV shutdown triger point to see if the problem lies from the HV going to high and if its shutting down from an overload then test the green crt. if thats good disconnect the green 2nd anode lead from the HV distribution block to see if its in the green tube or from the High voltage. Any way your gonna need a service manual and a schematic and you can order that from sams photo fact.com ood Luck
Posted on Apr 29, 2006
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Rolling horizontal line on screen
What was the reason for aquiring a new monitor?
Nov 23, 2008 | LG Computers & Internet
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Sony KP-53V80 53" Rear Projection Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
