-   blured pictures and blured lcd screen-   Guest
Feb 24, 2008
-   Veiw finder and lcd is dark. when i take a picture it is dark also. I have put in new batterys and reset the settings to the factory mode in setup.
Problem still persists-   Wmc1390
If you can see images in play mode, previously taken pics, then check to see if iris is opening and closing, could be seized vanes on iris motor.
If nothing is ever visible on LCD or the eyepiece, this is what the manual has to say- remove batteries, reinsert them after a minute. If it persists press the reset button with a fine tip, its located inside the memory stick/battery cover. all your settings will be cleared.
Sony Cyber-shot DSC-F717 Digital Camera. The screen is smudged horizontally and there is a green...
(More)
Sony Cyber-shot DSC-F717 Digital Camera. The screen is smudged horizontally and there is a green tinge, it is only on the viewfinder and LCD screen. When i upload the images to the computer they are perfectly fine. Is it possible to fix this problem?
Sony DSC-F717 will not operate in battery mode (replaced the battery). Works ok when power cord is...
(More)
Sony DSC-F717 will not operate in battery mode (replaced the battery). Works ok when power cord is attached.
my camera isn't taking any pictures even though it's on, and the lens is off. I'm pointing at...
(More)
my camera isn't taking any pictures even though it's on, and the lens is off. I'm pointing at objects, but the screen appears black, please help!
I would like to restore all the setting to original factory setting when I bought it. I followed the...
(More)
I would like to restore all the setting to original factory setting when I bought it. I followed the recommendation, removing battery while press power button, it didn't work. I'd like to set manuel. Do you have that info? thanks
external flash will not override internal flash - the subject ends up with very harsh over-lighting....
(More)
external flash will not override internal flash - the subject ends up with very harsh over-lighting. in other words, both flashes go off when i have the camera flash set "on". this is with the hot shoe function "off". if i turn the hot shoe function "on", then neither flash works (internal or external).
