Question about Garmin GPS
Sine the battery on my nuvi 750 is not user repalceable what happens when the batteries life is over
  • Garmin Master
  • 2,130 Answers
Most people will send it back to Garmin for replacement (expensive).. I have replaced many batteries on Nuvi's, although never on a 750. I'm sure it would not be that difficult for me to do so.
- Jim
Posted on Sep 12, 2008
Tip
How To Replace Your Garmin Nuvi 750 Battery
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
From NewPower99.com, this video provides a step by step demonstration of the procedure for replacing the battery in your Garmin Nuvi 750 GPS. The battery, along with the necessary installation tools shown in the video, can be found at: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
on Dec 31, 2009 | GPS
Nuvi 750 Car charger connection is intermittent.Either the Car charger or the Nuvi 750 connection is intermittent. The device will display a warning that it is using the battery - 27 seconds to turn o
It is very rare that it would be a problem with the Nuvi 750 GPS itself. This is because there are stationary gold pads on the bottom of the 750. No moving parts to wear out. We have seen problems with a bad plug on the charger that plugs into the cradle and the receptacle on the cradle can go bad as well. I would suspect more toward the cradle as we have seen the receptacles break away from the printed circuit board that is inside of the cradle. Best way to troubleshoot is to find a friend who has a duplicate charger and cradle and swap each piece, one at a time and see which resolves the problem... either the cradle is bad or the charger plug is bad. If you want us to test your unit, cradle and charger, let us know. Good luck! :) More info on charger issues here:
http://www.sharc.net/gps_charger_repair.htm
Apr 21, 2013 | Garmin nuvi 750 GPS Receiver
Can I recharge a garmin nuvi 750 on a computer or must I recharge in car only with clip on
you can use the computer to charge it via the USB, they do make house adapters that plug into the wall, very cheap to buy, and leaving it plugged in when not in use greatly extends the battery life. Go to ebay to get the house charger
Sep 19, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
When pluggin to the car charger and turn it on. it's a low battery and it keeps turning off. it doesn't charge. garmin nuvi 750.
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
May 26, 2010 | Garmin nuvi 750 GPS Receiver
Will not charge
THE BATTERY IS DEFECTIVE, IT WILL NEED TO GO BACK TO GARMIN FOR REPAIR, THE BATTERY IS HARD WIRED IN AND NOT SERVICEABLE BY THE OWNER/USER.
GO TO WWW.MYGARMIN.COM
May 14, 2010 | Garmin nuvi 750 GPS Receiver
Need to replace battery in nuvi 750
Is not wery hard if you have tools to open .
Try here for battery www.satnavservice.com
Aug 31, 2009 | Garmin nuvi 750 GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Nuvi 350 will come on but will not stay on
The internal batteries are not user replaceable. Please don't try to do this yourself. I've received numerous emails from people who have destroyed the Nuvi attempting to do this. I have replaced numerous Nuvi batteries. The life of the battery depends on how many cycles its gone through.
- Jim
Nov 29, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
GPS Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
