Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
1/2HP garage door opener, model 139.53640srt
The lights on both sensors went out at the same time. The door will open and close by holding the button in but will not work if you just push it one time. It was working fine yesterday. There are no obstuctins blocking the beam path. I was doing some sheetrocking in the garage and was careful not to go through any wires in the attic or the walls. The sheetrock is in place and has been taped already. I could use some help on this one.
Joe
  • 504 Answers
SOUNDS LIKE YOU DAMAGED A WIRE. TRY RUNNING TEST WIRES TO BYPASS THE ONES YOU COVERED UP.
WHEN YOU DETERMINE WICH WIRE IS BAD YOU CAN SURFACE RUN IT OR UNFORTUNATELY YOU WILL HAVE TO REMOVE SHEET ROCK TO MOUNT IT IN THE WALL. - DO NOT RUN THE WIRES WHERE THEY CAN GET SMASHED BY THE SHEETROCK OR SHORTED BY A NAIL.
HOPE THIS HELPS
Posted on Jun 05, 2010
Craftsman 1/2hp garage door opener works fine to open door but to close I have to hold button down. If not, door won't move and lights flash 10 times.
10 flashes mean sensors are obstructed... something is in the way of the door or they are not facing each other. Clear the obstruction or realign the door and it will work.
Aug 27, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2hp thinks it is not all the way up and will not go down
It is really a common problem for lightning or electrical surges to take out the logic board. Big expense too.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp won't open/close and learn LED flashes 5 times
The gear needs to be changed kit #41c4220a. Be sure to change the bottom bushing on the motor mount.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
CHAMBERLAIN LIFTMASTER PROFESSIONAL 1/2HP
Align the sensors and make sure the green light in on both sensors
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
280 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
