12,000 but/ton. If the 101 in your model is their tonnage (101÷12=8.4. its a 8 1/2 ton (5 ton and a 3 1/2 ton combined). That's probably it or very close. I could not look it up cause I don't know the maker of the unit.
This is a 3 and 1/2 ton unit. The 042 in the model number is the tonnage of your carrier unit. AC tonnage is based on 12,000 btu per ton. 12,000.....1 ton 18,000.....1 and 1/2 ton 24,000.....2 ton 30,000.....2 and 1/2 ton 36,000.....3 ton 42,000.....3 and 1/2 ton 48,000.....4 ton 60,000.....5 ton. There is no 4 and 1/2 ton unit.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal. Sincerely, Shastalaker7 A/C, & Heating Contractor
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help. Sincerely, Shastalaker7 PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
The mfg. date is sometimes (depends of the brand and the size of the unit) on the serial number.And the 36 in the model number means exactly what you think 36000 BTU or 3 ton.
36k-car-ms
Key Features
AC Type:
Split System
Additional Features:
Ductless
Cooling Capacity:
36000 BTU/hr
Electrical Requirements
Voltage:
220It is a 3 ton aprox 550 sq feet per ton is required
