Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Makita chuckless drill stuck full open - Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
  • Anonymous Oct 23, 2008
    broke it trying to turn the chuck to unstick ... bummer
  • Anonymous Apr 07, 2009
    I had the same problem on my Craftsman drill and the WD-40 solution worked like a charm.... thank you rowdy45176
  • 2,176 Answers
If you haven't fixed it yet here is the way that I have used to solve this problem. Spray some WD-40 on the inside of the chuck. Place a shop rag around the chuck and CAREFULLY grip with a pair of channel lock pliers set the drill rotation so that it will extend the jaws and SLOWLY depress the trigger. It should move. Let me know if I can help more. When trying this DO NOT SQUEEZE TRIGGER to full RPM.
Posted on Dec 20, 2008
    New Friend:
Thanks alot guys ..
I will try those methods ...
Posted on Jul 08, 2016
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
How do i open chuckless drill to get bit out
firmly grab the chuck, put drill in reverse, squeeze trigger
Jun 04, 2009 | Drills
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
923 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
