Question about Kenmore Washing Machines
We need to replace the switch that allows the spin cycle to work with the lid down. The back is one solid piece we dont know how to get to the timer to plug in the new switch we bought
  • Anonymous Jan 17, 2009
    Same problem! My spin switch is definitely broke so I took out the two screws to remove the broken part. It is (of course) attached to a cable. I need to get the entire lid off so I can remove the spin switch and replace with the new one. How in the world do I get that top part off?
  • 1,239 Answers
    • hi sir..
    •  here the the details of the lid switch..
      if any problem i am there to assist u,, thank u..
Posted on Sep 12, 2008
  • 5,911 Answers
What you are talking about is called the "lid switch". The following link explains how to replace one on a Kenmore top loader:
Make sure you check to see if the switch is simply loose. There should be some mounting screws holding it in place. In addition, there is usually a small plastic piece mounted on the washer lid on most Kenmores that activate the switch when the lid is closed. This is called a "lid strike". If the mounting screws are loose, or if the lid strike is broken or missing, the washer will exhibit the same symptoms as having a broken lid switch. For replacement parts, refer to and type in your complete model number (located along the washer lid opening). The parts you need will be listed under the "Top and Cabinet" heading.
I hope you find this information helpful. Let me know if you require additional assistance.
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My washer will not drain the cycle will run but when it comes to rinse it it fills but wont drain or spin.
the timer switch is defective....have the timer switch can also usually take them apart to clean them for re-use but it's not practical if you don't know's best to replace's also safer because there are high voltages and currents inside and unless you've worked with electronics and electrical circuits, i don't recommend that you do it yourself....good luck
Jun 25, 2010 | Washing Machines
Kenmore washer won't agitate, spin, or drain
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
If the switch requires replacement, a new one can be purchased on line at,,, or The average cost of a replacement is $25 to $35.
Let me know if you have any questions, I hope this helps you.
Aug 21, 2009 | Washing Machines
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
When washer goes to spin cycle starts a loud noise, like hiting
you are holding down the lid switch, and being sure that it is heald all the way down at all times while performing this test.
it sounds like the brake is kicking in because the lid switch is being released,
if you are holding the lid switch and it doesnt start to spin, try to assist the basket a bit, if it begins to spin a bit you would need a new clutch because it is saturated in oil. did you notice any oil when replacing the coupling?
but worst case senario would be a transmission.
Jun 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will do everyything but final rinse
Sounds like a lid switch to me. The symptoms you describe are often caused by a lid switch malfunction. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at Just type in your model number and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949238). The lid strike is listed as item 20 (part #350733). You may also check They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually costs between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: Future reference (this is just constructive advice), if you are in the habit of slamming the washer lid or placing heavy objects on the it, this will cause damage to the lid switch. In addition, also make sure your washer lid is not bowed. Placing objects on the lid can cause the lid to bow and prevent it from making the proper contact with the lid switch. This will give you the same symptoms.
Aug 22, 2008 | Washing Machines
Washing machine stops at spin cycle and now won't run at all
Possibly the lid switch. It won't spin if it doesn't know the lid is closed. Some washers won't agitate with the lid open either, so let it fill until it starts agitating, then lift the lid. If the washer stops you know you've got a good lid switch. If it keeps going you know you need to test the lid switch. Just hearing if it clicks or not is not always a sign it's good. Some Maytag/ Admiral washer lid switches have more than one contact that must close to spin.
It could also be a problem with the timer. Put it in the spin cycle where you know it should be spinning. Make sure the lid is closed. Grab the timer knob and try wiggling the timer shaft up and down and around without turning the knob. If it starts and stops you've got a bad timer. You may still have a bad timer if nothing happens, but you'd have to check it with a meter.
Jul 21, 2008 | Admiral AW22 Top Load Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Malber p21 spin
the lid switch must be broken if you know how to use an screw driver you can fix it remove the lid witch and replace with a new one, remember to unplug the machine frome the wall...good luck
Aug 04, 2006 | Malber P21 Front Load Washer
Open Questions:
Washing Machines Logo
75 people viewed this question
Sal De
 Brian Main
Brian Main
