Question about Optoma H30 Multimedia Projector
Sansui home projector san501A stopped going, replaced old bulb, had to send to australia for this and cost me about 150.00 still not going. whats' the trouble.
  • 286 Answers
Could be anything.
One of the fans might not be turning. The projectors I work on here have3-4 fans, and they all have tachometers (a third wire). some times the tac goes bad and the fan has to be replaced. The only way to tell is to use an oscilliscope to measure the signal from the fan, or to replace the fans one at a time. If that doesn't fix the unit, then you might have a bad: power, main or ballast board. Again, the only real way to find out which is by measuring or substituting.
Posted on Nov 04, 2008
Dell dlp front projector model 2400mp parts
The bulbs are very costly and they have a short life as is. Stop replacing and get a new unit. The repair is not worth the cost and a new unit has a warranty for at least a year.
Feb 27, 2014 | Office Equipment & Supplies
Can I still buy a new 150watt bulb for an old Elmo Slide Projector CV and CS
never tried them personally but you could try
http://www.bulb-source.com
Jan 23, 2013 | Elmo Projectors Office Equipment &...
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
It is just very dim. The bulb has 500 hours - is it just a bulb?
This projector had a lamp rated at 2000 hours (normal) / 3000 hours (eco mode). It last shipped in August 2008. It is a 3000 lumen projector. It's a reasonable business class projector.
As a first step, it's certainly worth checking your warranty status. Your projector will certainly be approaching the end of its warranty now, however this model was shipped with a 3 year warranty so it may still be covered if the fault is not the lamp. Check now, and log the (possible) fault with your local Hitachi service dept. eg http://hitachiserviceeu.com/support/contacts/contacts.htm
Essentially it is hard to say. You might find that replacing the lamp makes the projector considerably brighter. A new lamp in an old projector does not return the image to a showroom state though due to degradation in the LCD panels, and dirt etc.
If the projector is not displaying any sign of other fault (ie. it will run happily for a decent length of time, and there are no warning LEDs) it might be worth considering replacing the lamp. A new lamp will cost cost around £250 or $250. If you are going to replace the lamp before sending it for "repair" make sure you fit a genuine Hitachi lamp as non genuine lamps can lead to warranty problems.
Feb 15, 2011 | Hitachi Lamp CP-X400 CP-X200 -...
My EP 758 is 4 years old and has 1500 hours on its second bulb. I use it for home use with a satellite input (dish network). It just started flickering a couple days ago. The main picture is still there...
It sounds like the projector itself has a fault. Sadly it's often uneconomic to repair budget projectors which are out of warranty when the cost of repair is compared to that of replacement. You should speak to Optoma support and see who their local agent is, and then ask for a quote.
UK support can be found here
They will usually charge a fee to have a look and then they'll offer an estimate for repair.
Feb 14, 2011 | Optoma EP758 - HDTV Compatible DLP...
HP vp6320 projector ten seconds it shuts off
I had the same problem, the first couple of replacement bulbs i ordered worked fine but the last 3 i got, 2 of them have been faulty, i just sent them back and they replaced them. If its too late to send the bulb back you can go to the settings on projector, select lampsaver setting, its probably set at off, turn it on. Your bulb will be a little dimmer in this setting but shoud let the projector run ok.
Dec 01, 2008 | HP vp6320 Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Optoma H30 Multimedia Projector Logo
358 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
