Question about NEC (50019497) Projector Lamp for VT440, VT54
NEC Projector VT440
Used every day in our school. Recently had new bulb and has had polariser replaced in the past. Image is fading, adjustments to colour, etc. makes no difference. Video is Ok-ish but image from computer is terrible, very faint and white background is blue-ish. Any ideas that won't cost a lot?! We have to decide now between spending more money (we've had this one about four years) or buying a new one.
  • colerhe Jan 10, 2008
    My projector sounds like it's working but no image comes out. If I shine a light down the front barrel I can see the image of my computer monitor so I think it is just the bulb. The problem is I can only find whole lamp mechanisms for sale $510. Does any one know how to just replace a bulb and where do I get them?
I am a computer and electronics tech for a school district. I have worked on a number of different model projectors. The biggest problem that I see that can wear out a bulb VERY FAST is dust in the filters. When the filters get clogged with dust, the projector cannot move the proper amount of air to keep the lamp cool. These lamps run extremely hot and if not cooled properly can fail very fast. The first sign of a failing bulb is that the picture gets very dim. This is a good sign that the bulb needs to be replaced.
Another thing that can reduce the life of the bulb is leaving the projector on when it is not in use. If you are not using the projector for an extended period, shut it off. Leaving the projector in an A/V muted state does not shut down the bulb completely and can still wear on the lamp hours. These bulbs are rated for a certain number of lamp hours, so any time the projector is on, it is wearing away the hours of useable time. And at the cost of these bulbs, this can get expensive.
Most companies that sell bulbs sell the entire bulb assembly which is the bulb in an easily removeable housing that is usually made of a heat resistant plastic. One place that I use for replacement lamps is a site called my projector lamps http://www.myprojectorlamps.com. This site will sell you the entire bulb assembly for a reasonable price. If you feel confident enough and have a bit of mechanical ability, you can usually get the bulb alone at a cheaper price and replace the one in your existing housing. Bulbs for some of these can be a bit tricky to replace in the plastic housing, so check out your assembly before going and ordering just the bulb. You may want to even try getting the bulb out of the housing first to make sure you can do it. That way if you damage the housing in any way you can then order the complete assembly.
Posted on Apr 14, 2008
    Champion:
  • 277 Answers
Hello first thing try changing the cables if the the image coming from computer is rubbish then the video card is probeply bad try replacing it with some other one an every day use can easily exhausted every proudact there is out thereif all these wont help I believe it will be best if you will buy a new one then fixing it... good luck have a good 1
Posted on Apr 30, 2006
4 Suggested Answers
  • 4 Answers
SOURCE: NEC vt440 projector is overheating
Try cleaning the filters, there is one on the front and one on the side. When dust builds up on these it can restrict the cooling of the projector
Posted on Nov 22, 2008
SOURCE: NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Posted on Apr 18, 2009
m_peel
  • 76 Answers
SOURCE: I have a nec 1050.
It sounds like a polariser lens has failed, if so it may be cheaper to purchase a new projector than have it repaired.
Hope I was of assistance to you
Posted on Aug 05, 2011
Epson 822+ Projector still dim after replacing bulb
I'm not familiar with your specific model, but are the units LCD or DLP? What I've seen in LCD projectors used in schools, museums, etc. that are left-on for several hours per-day, is that the UV filters in the optical blocks will fail. They usually change to an amber-brown color and block most of the light. It's the equivalent to putting sunglasses on. Do the units also exhibit a greenish-yellow tint instead of proper color?
Apr 25, 2013 | Epson Office Equipment & Supplies
Problem with a Viewsonic pj800 LCD projector. The image looks like it's not aligned properly. Like it's a double image and the color is all distorted. I imagine there is something wrong with the...
The image is made up of three polarisers, one tends to fail causing a problem with the image. On average it may cost £300 per polariser to be fixed. As you know these days you can get a projector for that price as everyone now wants HD and 3D. I recently bought 7x NEC NP115 for just over £200 each. Very good spec, auto power up (Which was important for what I needed)
hope that helps
Aug 04, 2011 | ViewSonic Projector PJ800 Multimedia...
Hi there! i have this nec mt1030g+ projector and its video hv sumthing like a copy of image with is like shadow of the real image in blue colour! i wanna know if its lamp fault or sumthng elsa! thanks
It sounds like a polarising lens has failed, if so it will probably be cheaper to buy a new NEC NP115 which has probably got the same if not better specification.
Hopefully I was of help to you
Feb 04, 2011 | NEC MT1030G Replacement Projector Lamp...
Eiki LC SVGA 870. on screen the image edges are blurred and the green colour edging can be seen
Aug 04, 2010 | Office Equipment & Supplies
Seeing a blue "haze" on presentations, and when on blank screen
On the "Option" menu, try selecting "Service" and the "Factory Reset". This may help. If not, you will have to use the menus to manually adjust the level of blue in the projectin. Go here for the manual for your Hitachi and you will find instructions:
http://www.aboutprojectors.com/pdf/hitachi-cp-x445-manual.pdf
Feb 26, 2009 | Hitachi CP-X445 Multimedia Projector
Cant see anything
this is a fairly old model!
the lcd optic engine requires cleaning as the mirrors inside will be dusty,also from what u have mentioned,it appears that the polarising filters inside are damged.pl check if the image that u see is spotless.if it has permamnent patches of green or red or yellow, then the polarising filters are damged & u need to change them!
Dec 28, 2008 | Philips LC 4500 projector lamp Projector...
PRINT COLOUR IMAGE FROM GOOGLE IMAGES
getting vertical lines on my pictures . i have a epson cx5000.
Jun 08, 2008 | Epson Stylus C66 Inkjet Printer
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
RCA DLP HDTV POOR COLOUR - TOO MUCH GREEN
Hello:
It sounds like your light engine needs replaced, should be around $400.-600. depending on who does it. I have seen the lamp cause similar symptoms but not that likely.
Feb 29, 2008 | Televison & Video
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
See all NEC (50019497) Projector Lamp for VT440, VT54 Questions
NEC (50019497) Projector Lamp for VT440, VT54 Logo
757 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
