Question about Cat5e Computers & Internet
Transfering data from one computer to another
How to transfer data from one computer to another using Cat 5E
crossover Cable
  • lowelllynn Sep 12, 2008
    I have a RS-232C Cable. I want to transfer data from one computer to another. How do I do that. or how do I connect the two computers?
    Lowell Lynn
  • 6,487 Answers
You can check this link for the step by step way on how to setup that type of file sharing http://www.conniq.com/WinXPNetworking_Ethernet_direct_connection.htm
Hope that helps..........
Posted on Sep 12, 2008
  • 928 Answers
Use a crossover cable.
On the first computer.
1. Clicks start then run then type in ncpa.cpl
2. Right click on local area connection then click on properties.
3. Click on TCP/IP and click on properties.
4. Type in as an ip 192.168.1.5
5. SUbnet 255.255.255.0
On the second computer.
4. Type in as an ip 192.168.1.6
On both computers Right clck on My computer then click properties. make sure that they have the same WORKGROUP name and different computer name.
On a folder go to Tools then folder options. Select the option for View then select USE SIMPLE FILE SHARING.
on any one of the computers that you want to share the files. Just right clck on the folder you want to share then clck on Sharing. Enable sharing.
  • Thomas Lim
    Thomas Lim Sep 12, 2008
    It is very much possible to do it with the cable that you have but it will be very slow and impractical for any use unfortunately.
    Genius:
  • 1,239 Answers
Connect a cat 5E jack on one end. Start with a 568B connection at the jack. ... I took thecomputer to another cat 5 location, and it worked fine. ... and here is the useful link.. about it
  1. www.lanshack.com/cat5e-tutorial.aspx . thank usir.. rate it..
Posted on Sep 11, 2008
    Master:
  • 726 Answers
I think there is no way to do that. You CAN do it, however, with a crossover cable. It looks the same as a regular cable, but it's not. With the crossover cable, just connect the two computers and give 'em two IP's in the same network. Then enable file sharing and it should work. Sorry, I can't go into much detail because I haven't done that in a looong time, but I think that's about it. Hope it helps.
25m and no signal
Two equipments of the same type - two computers, two routers, two switches - should be connected with a crossover cable.
Jul 26, 2013 | Cat5e Computers & Internet
Tip
My cat 5e
how to terminat cat5e cable either crossover or direct terminiting and how to arrange them fix it with the rj45
on Apr 16, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
I have two computers. One is connected to the internet with a cat 5 cable. I bought a new cable for the new computer which is a fastcat 5. However, I cannot get this computer to work on the internet. If i...
I'm assuming that you have a modem or a modem and router combination with multiple cat5 ourputs. You have tried both computers with the Cat5 cable and they both work fine. If this is the case, I would suspect that you have a faulty fastcat 5 cable.
Feb 14, 2011 | PC Connection FastCAT 5e Patch Cable...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
Nokia 6233 mobile switch on but then hangup
Dear
When u connect to computer by data cable it shows three option, select data transfer option from it to transfer file like videos,music etc.
while in this process phone will not displays menu option it shows data transfering
if u want to display menu option u have to deattach usb data connection
Thanks
Feb 20, 2009 | Nokia 6233 Cellular Phone
Data Rack
cat 5e making networking cable setting. Please tell me setting pc to hub and how to networking cable connect the conector.
Jan 26, 2009 | Computers & Internet
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
Single-line data transfer
No, a data transfer cable always need send and receive to be sure the packet of data are reaching the destination.
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
218 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
