Question about GE JVM1330BW/WW Microwave Oven
Loose door handle
The handle on my microwave door has come loose. Can I replace or tighten this myself?
  • Ray Wright Jan 01, 2008
    The door handle GE parts gave me has two screws. I took the inner cover off I could see the two screws and removed them, Once you get the two screws off what do you do? It still seems locked in place?
  • 513 Answers
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
The handle on my frigidaire galary microwave is loose on the bottom end. How can I tighten it?
most door handles have a screw in it from behind, or inside the door. so must disassemble the door to replace. check price before taking apart. sometimes very expensive plastic or not available.
Feb 18, 2018 | Microwave Ovens
Goldstar Mv1526W
is the lock/screw was loose//?
Jun 11, 2008 | Goldstar MV-1526 Microwave Oven
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
How do you tighten the handle on the microwave JKP78G0K2BG
You need to remove the screws that are holding the frame of the door to gain access to the rear of the handle assuming that the handle is not stripped out to start with.
Jan 30, 2013 | GE Microwave Ovens
The handle is loose on my icon microwave
Some of the handles have a cover like that you pop off and then there are the screws. good luck hope you have this kind.
Jul 17, 2012 | Electrolux ICON Built-In Microwave Oven
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Jun 06, 2012 | Electrolux ICON Microwave Combination Oven
Loose handle.
To access the door screws on MOST microwave ovens, you need to remove the inner door panel that goes around the perimeter of the glass. The following link explains:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This can be peroformed with the door in place, or with the door removed. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 18, 2010 | Kenmore 62622 Microwave Oven
Door handle is loose
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door. You will find the screws behind the panel.
If you have questions, please let me know. I hope this helps you.
Jul 13, 2009 | Microwave Ovens
Loose Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sorry, but I can't be more specific on non-US models.
Hope this helps!
Jun 17, 2008 | Neff B7740N0GB Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
1,067 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
