Question about Acer Computers & Internet
Hi. I spilled coffee on keyboard ACER 9410 laptop. Now a couple of the keys do not work and screen jumps when I hit some keys on right side of keyboard. Can I replace the keyboard to fix the problem and how do I change it?
I did the same thing. Here's what I did:
Took whole thing apart. Cleaned any coffee with q-tips dipped in water / paper towels. Removed the keyboard. Ran it through the dishwasher with no soap in it and heated dryer off of course.
I let it dry for a day and was bummed that now the whole keyboard stopped working. Well then 4 days later to my surprise / delight.. the whole thing started working again. New keyboards on ebay were also very reasonable. But mine still works perfectly after the dishwasher cleaning.
Posted on Apr 02, 2009
Spilled coffee on keyboard now screen flickers
I wash once a laptop keyboard after someone spilled beer on it. Try to unmount keyboard and wash it with water and soap. It works for me. Let keyboard to naturally dry one day.
Jul 21, 2012 | Computers & Internet
When i type f it searches, when i type m it minimize the application, when i type L it loguot...my laptop is acer aspire
The Ctrl key got stuck, either mechanically or electrically (liquid spilled?).
Sometimes it helps to hit the stuck key (actually two, left and right) numerous times, and restart the computer.
Sep 23, 2010 | Acer NSK8458AN Keyboard
HOW TO YOU REPLACE THE WHOLE KEY BOARD FOR A ACER 4720Z I SPILLED COFFEE ON THE KEY BOARD. EVERYTHING WORKS BUT THE ANY KEY I HIT I GET A I THAT IS STUCK
IS YOUR MACHINE IS UNDER WARRANTY IF YES LOOK FOR ACCIDENTAL COVERAGE OR CLAIM A HARDWARE FAILURE....THIS WILL REPLACE UR KEYBOARD FREE OF COST...OR YOU CAN BUY FROM HERE
Jun 16, 2010 | Acer Aspire 4720 Notebook
Spilled coffee on the keyboard and now only some keys are working, some are not, and some are stuck. How do I get the keyboard off?
Open the laptop, pry up the right hand edge of the strip above the keyboard and lift it slowly working from right to left so it snaps out of the base unit. You will then see 2 screws on above F5 and the other above F10, remove these screws and lift keyboard out far enough to detach the ribbon cable underneath.
Apr 12, 2010 | Acer Aspire 3100-1405 Notebook
Spilled Coffee on HP Laptop--miraculously it works with errors
It depends on how damaged the keyboard is. Electronics get very touchy about such things. If you let it dry it may work, but there may be some circuitry damage. You may need to seek professional repair if the board doesn't start working. Also, you could get a new keyboard for it and install it yourself. Until you do this go get a desktop keyboard and that should get you by. Keep an eye out for other problems, the coffee may have gone deeper into the laptop and may have gotten onto the motherboard. Your files should not be in danger anymore, because it is somewhat hard for liquid to get into a hard drive (unless it causes a surge).
Feb 08, 2010 | Toshiba P000171240 Keyboard
Acer laptop keyboard repair. I spilled coffee in my keyboard and now some of the keys dont work. The computer itself works fine. How do i get the keyboard out to clean or replace it? Thanks Abe
ok here u go u havent given me model of ur notebook but it is almost the same procedure normally all casings are same to open
see this link for details
http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
pls rate me FIXYA fo rhelp
Apr 11, 2009 | Acer Computers & Internet
Acer 1690 keyboard arrows problem
Sounds like your number lock maybe be on. It could also have a shortcut function option that is on. If not, have you spilled anything on it lately?
Mar 22, 2009 | Acer Aspire 1690 Notebook
HPG60 Laptop - coffee spill - mouse not working
well this is a common thing but most likely the motherboard was shorted out and causing glitching. I would take it to a tech to see if there is anything recoverable in there
Feb 11, 2009 | Computers & Internet
Due to sugary spill, 4 keys not working on keyboard
Simply stated, yes.
If you plan to do that, in the meantime you could also run the keyboard under a warm shower for a new minutes and then hang it out to dry in the sun. I'm not kidding. It will probably, that is probably, work just fine after that so long as all the water has dried and drained out and its not an IBM mechanical keyboard.
Regards,
Worldvet
May 24, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
