Question about RCA P61830BL 61" Rear Projection Television
Toshbia Projection 50''
I have a 4 year old 50" Toshbia Projection TV. Model #50H82. I turned it on today and the picture flashed and faded then it went out. The picture is no more. I even tryed the menu from the TV and remote, nothing. The sound does work though. Does anyone know what it could be? Is it expensive? Thanks So Much.
    President:
  • 3,130 Answers
A few problems come to mind. The high voltage block took a dump and opened up. The filiment supply from the HV sweep has cold solder connections on the Printed circuit board. Another problem is the most common of all could be a vertical sweep falure like the vertical output IC or the b+ going to the chip or maybe even a bad yolk connection on the solder side. Good luck
Posted on Apr 28, 2006
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
How do I know I need a new projection lamp? My tv
This set does not have a lamp. It has 3 crt tubes that converge to create a color picture. The convergance is off a little causeing this affect. Go into the menu and look for convergence or magic focus. You can download the owners manual from Toshiba website to do this. You will need the remote that came with the set.
Nov 30, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
50 inch screen
I will check when I get to work tomorow and see if we have one and I will repost tomorow
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Oct 23, 2007 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
