Question about Dryers
Whirlpool Dryer - Gas
I have a natural gas dry, model # 66W9878LW0, that does not heat. I believe it is the ignition system since gas is getting to the appliance. How do I go about testing the ignition system?
  • 943 Answers
HI oNDRYERS THERES A THERMAL FUSE LOCATED ON THE AIR DUCT .tHAT GOES OFTEN CHECK THAT FIRST IF THATS OK tHE IGNITOR DOES GO THAN THERES THE FLAME SENSOR aND THE COILS ON THE GAS VALVE . bUT MOST OF THE PROBLEMS THAT OCCUR IS WITH THETHERMAL FUSE
Posted on Sep 12, 2008
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
My natural gas maytag dryer does not provide hot air to dry the clothes. It apperas the gas is not igniting because after it tries it smells like gas. I beleive it could be the ignition source.
heatman101
Jul 17, 2011 | Dryers
Clothes not drying completely; takes about 5 cycles to get them dry. Was previously drying completely with one cycle. I believe I need a new heating element and would like assistance on getting...
heatman101
May 20, 2011 | Whirlpool Dryers
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
Whirlpool Gas Dryer (ggq9800pw1) - No Heat
You have a leak somewhere in your gas system, Either from the gas valve or some other tubing. In this situation unless you understand how it works I would recommend getting a tech out to look at your system. That way you know that it is being done properly.
Jan 02, 2010 | Whirlpool GGQ9800L Gas Dryer
No heat, blowing cold air
Hi, You will need to change the coils. They get weak later in cycle and will not open the valve.
Does the moise accur when the gas ignites in the first part of the dry cycle. It is possible the gas valve is starting to go bad but, it is not very common.
Here is how to change the coils:
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGR5636L Gas Dryer
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer not heating up
It does not have a pilot. It uses a glow bar ignition system. You probably have a bad glow bar if it is not heating at all part number 279311
Apr 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
Top Dryers Experts
