Back to:
Tags:
T-Mobile Sidekick II
My phone dosent turn on or nothinq (by 27 users)
posted by MimiN on Apr 28, 2006
I had the phone for a while.. and now.. i dont kno.. it dosent charge it doesent turn on. nothinq and people tell mi that maibe is that the battery died but i dont know cause it dont even charge.. i try to take out the battery and all.. but it dont do .. nothinq
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
26 Other Users Have The Same Problem
Comment by clown 1, posted on Aug 27, 2008
I have a Nokia flip phone. It was working fine then one day it decided to turn itself off and now won't turn back on. I tried charging it but nothing happen,the light didn't even come on,I also tried taking the battery out,but still nothing. What else can I do.
Comment by Guest, posted on Aug 25, 2008
changed the battery but now it only lasts about 6 to 8 hours
Comment by augie69, posted on Jul 29, 2008
i have the same same problem my mpx 200 is not turning on. pls help
Comment by Guest, posted on Jul 13, 2008
Battery died on my phone when i went to charge it it doesnt seem to charge and now it wont turn on or charge.
Comment by cricket82, posted on Jul 04, 2008
my palm wont turn on, if i put it on the charger it will power on but if i take it off it goes back dead with no charge and anything i put on there ( time, date..etc) it erases it as well...do you think its the battery or what..any suggestions would be helpful..thanks...christina
Best Solution
posted on Mar 12, 2008
FixYa! (100)
ayork
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My phone dosent turn on or nothinq:
I don't want to Accept this solution
Solution #2
posted on Dec 28, 2007
FixYa! (100)
chinb
i got my sidekick two a week ago the phone shut off wednesday of this week but the phone dont turn on and when i plug it out and plug it in back the phone says its still dead so i am wondering how long does a very dead barttery be fully charged that i can turn it on .
Thank You!
Solution #3
posted on Jan 13, 2007
Helpful (85)
raucous
Rating: 90%, 1 votes
my phone had the same problem. Tried another bat,did not work. tried my bat in another phone and it worked. so from that i deduce that it is not the bat. What else can it be?
Thank You!
Solution #4
posted on Jan 22, 2007
Helpful (85)
JayMatt
Rating: 78%, 8 votes
One more thing. There was a possible solution on a website I came across, but I dont' remember which one. Sorry.
The restart feature described how each of the pins of the USB connection needed a specific range of voltages to properly power the phone. However, ONE of the pins (I dont remember which) will restart the phone if the voltage applied is out of the required range! I wish I could find this site and run a test case on my phone. If it works I'll be sure to tell everyone. If you know the site, please let me know! Thanks!!
Thank You!
Solution #5
posted on Apr 30, 2006
Thanks for Trying (70)
windman
Rank:Wiz Wiz
Rating: 77%, 799 votes
hi
well, way dont you listen to all those how told you on the battery?
from your description it seems to be the battery - its dead
it cant charge and there for the phone wont turn on
if you take out the battry then the phone wont have even a hope to light up - wont it?
does it work well when you plug it with the AC adapter?
if soo then its most certainly the battery!
buy a new 1
good luck
Thank You!
Solution #6
posted on Feb 01, 2007
Guest
Rating: 0%, 0 votes
my treo 600 wont charge it stayes about 15% and there is a new battery in it
Thank You!
Solution #7
posted on Oct 06, 2008
Not Rated (0)
kadice23
Rating: 0%, 0 votes
my sidekick slide is not turning on even if its on the charger i dont know whats the problem
Thank You!
Solution #8
posted on Aug 28, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Not to nitpick on an unrelated thing, but how did you manage to even spell "phone" much less purchase one? Unless English is your second language, you need to go back to school and learn to spell...just a suggestion.
Thank You!
Solution #9
posted on Mar 27, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
When the battery is 100% drained , there is no way it can be charged again from AC/DC Adaptor or USB Cable .. it needs to get charged at least 30% from some phone repair shop so it will work .. i had the same problem .. So dont get it to Drain 100% ever ..
Thank You!
Solution #10
posted on Feb 18, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
dont buy it because it will just break agian
Thank You!
Solution #11
posted on Jan 16, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
On the HW6500 series there are two small pips on the inside of the rear cover. One of them operates a tiny switch which is supposed to switch off the battery if you take the cover off with the power on. BUT if the plastic rear cover gets warm as it often does in your pocket then the case will move a fraction and poof your ipaq goes off or resets. Be very careful when you put the rear case on - push the pips into the holes and squeese hard as you slide the cover up. Plug into charge for a few minutes and the red light should change to orange. Leave it charging over night and all should be well again. It is a bad design fault - in extreme cases you may have to get a replacement rear cover - quite expensive. can any one tell me if you can short this switch out somehow?
Thank You!
Solution #12
posted on Jan 06, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
help!!!!!!!!!!!!!!!!!!!!! it still wont turn on
Thank You!
Solution #13
posted on Dec 11, 2007
Not Rated (0)
Alian
Rating: 0%, 0 votes
hi
i buy it today its in safe package and this is my first use but battery dont charge its normal? and i must buy another buttry? or this is another problem
if this is from battery whay in first use and first day? motorola company place a dead battry in package ?
Thank You!
Solution #14
posted on Nov 20, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
People, please listen. I had the same issue with the sidekick 3. It stopped charging. I bought a new battery and a new charger and guess what? It still didn't charge. Save money on all of those items and just get a battery charger. It will save you money, aggravation and your precious time. Get it on ebay...Mac
Thank You!
Solution #15
posted on Jul 27, 2007
Not Rated (0)
Diterex
Rating: 0%, 0 votes
I had the same exact problem with mine. I had to buy a new battery and a desktop charger from ebay. It seems that the battery goes so far dead that it won't even allow you to charge it using the phone. So you have take it out of the phone and put it into a separate charger give it a little time and it will come back to life.
Thank You!
Solution #16
posted on Mar 27, 2007
Not Rated (0)
CutzDaGod
Rating: 0%, 0 votes
The USB trick worked...I just did this for my phone
Thank You!
Solution #17
posted on Mar 09, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Have the battery rear cover switch checked if you have already conirmed that the battery is faulty!!!
Thank You!
Solution #18
Not Rated (0)
JayMatt
Unfortunately, it is not always the battery. My phone's battery died and the phone is now dead, permanently. The AC adapter doesn't charge the phone or allow it to power on. Something in the phone is "stuck". The phone will boot into the bootloader, but that's it. We cannot flash the phone at all. Sorry, but there doesn't appear to be a fix for this problem and Motorola isn't interested in helping. Good luck!!
Thank You!
Can you Help with these PDAs problems?
bought a sidekick slide from internet. suppose to be...
i bought a sidekick 3 from my friend. the...
i need to find my imei number it does not come up on the...
I have unicel sim card and sidekick asks for code,...
I need to get my device apart, I think: the...
26 Other Users Have The Same Problem - Continued
Comment by Smitty09056, posted on Jul 02, 2008
I have the same problem my phone doesn't turn on. It wouldn't even blink. I put it on the charger it does nothing, pluged it into the computer still nothing. i finally got ther light to start blinking so i quickly put it on the charger it has been charging for about 5 hours with no change. still will not power up. anyn suggestions.
Comment by Guest, posted on Jun 30, 2008
yea my sidekick slide isnt working.it had died nd took me a while to get acess to a charger.so it wouldnt charge.but if you have a sidekick slide usb cord connect it to the computer it should work in 30 min or so
Comment by Guest, posted on Jun 05, 2008
it wont turn on or even light got it a new batery same sh*t wont turn on
Comment by hassan9270, posted on Jun 02, 2008
My phone does not turn on, remove the battery and put it back on, nothing happened still can't turn it on, put it to charge still nothing..
Please anyone can help????
Comment by Guest, posted on May 25, 2008
the red light on top blinks but that all it dose
Comment by ProfMowry, posted on May 24, 2008
My phone turns on and off and on and off. It tries to boot up but then turns off. I have taken the battery out, the sim card, recharged. It seems to be caught in a loop.
Comment by OmegaRed7, posted on Apr 29, 2008
it wont turn on after i turned it off
Comment by bradyweb, posted on Apr 08, 2008
I used my phone to make a video, which it successfully did, then put it in my pocket as usual and only about 5 minutes later I took it out of my pocket and it was completely dead. By coincidence I had checked right before I made the 30 second video and I still had 60% of my battery. My phone now has no sign of power. There are no lights at anytime, the lights do not come on when I try to charge and the phone will not come on at all when I have it hooked up to the charger. Any suggestions?
Comment by help a 1200, posted on Apr 03, 2008
i have a motorola a1200 at first it work fine then one day it just froze a red screen now it won't even turn on but if you was to plug it up to a charger then the screen will flash ...
Comment by jim_66, posted on Mar 28, 2008
does anyone know if these are fixable after they get wet?
Comment by abbz, posted on Mar 14, 2008
sent it back to the guy i bought it off.......e.bay
Comment by Guest, posted on Mar 09, 2008
saaamer herre =\
Comment by dboyloya, posted on Mar 06, 2008
same problem phone doesnt charge
Comment by abbz, posted on Feb 13, 2008
bought one of ebay. has no battery what do i need to buy as it will not charge.
Comment by celeste56, posted on Feb 12, 2008
My phone died. Bought a new battery. The phone would come on but not charge. Tried using the data cable to charge. Same thing..phone comes on but does not charge. The guy I bought it from on ebay won't replace it or do anything. I have only had this "new" phone for three months. Although after a little research, I found out that it was probably manufactured in 2004!!!
Any ideas??
Comment by chujee, posted on Jan 18, 2008
i have the same problem, whereby my phone won't switch on and there is no lights whatsoever when i tried to charge it. At first i thought it was my battery so i bought a new one. it still doesnt work so it has to be something wrong with the phone. please help. thanks
Comment by JustBun2003, posted on Dec 19, 2007
The phone doesn't power on and the phone doesn't charge as well.
Comment by maia chloe, posted on Dec 15, 2007
it doesn't turn on,and it cannot display the homescreen,i thik its in the programs of my phone..what software should i use to reformat my phone?pls..help me.
Comment by Guest, posted on Dec 13, 2007
same exact problem. the phone does not even work when plugged in only the red light in top right corner temporarally flashes.
Comment by Guest, posted on Nov 07, 2007
help does not switch on even when on doc it goes on but dies when taken off !
Comment by Mayzee, posted on Nov 07, 2007
My XDA mini s Phone will not charge & there is no led light.
I have tried a new battery and a new mains charger cable.
The instructions state to charge the battery with a mains cable supplied for 8 hours. No such luck. Help!!!!!!!
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
