Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Lars Lite 2 pool heater will not ignite
Turn the heater on to POOL and the igniter lights up / glows but the main burners will not ignite. Could this mean the thermocoupler needs replaced? OR??
The easiest way to troubleshoot any heater, is to call the manufacturer. Their techs will walk you through each possible problem and solution until you find the answer.
Posted on Oct 03, 2008
Why won't my Hayward H Series H200 pool heater not lite, what is the most likely problem
there are a few things you can check. make sure you have a good fuel supply. make sure the pilot light is lit. (just because the pilot is on doesnt mean you have good fuel supply). the pilot may be out of adjustment from the burner rail. the igniting burner rail may be dirty or blocked
Aug 13, 2014 | Hayward H Series Pool & Spa Heater 200k...
Jandy Lite 2 heater won't ignite FL4 code?
So, you replaced part R367100 (Igniter)? This part if very susceptible to failure if touched. I would inspect and/or run a continuity check to make sure it has non cracks. Does it glow red when you attempt to start the heater? Remember, that is the how it ignites the flame, by getting red hot.
If it glows red hot, but does not light then I'd do the following testing in between;
Check that the inline fuses on the igniter aren't blown,
Check if the control board is sending a charge,
Check the flame sensor for gunk build up. Unfortunately to replace the flame sensor look like you have to purchase a whole new burner assembly to get a new flame sensor.
I also believe there is a toggle switch on the front door. It may need to be depressed before the system will ignite.
May 10, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light is on - but will not ignite burners
The thermal bulb is mis alinged or is defective and can be bought at any hardware store cost's about $45.00 an takes 1/2 hour to change out. you may want to make sure the thermal bublb is directly in the path of the flame as this will cause it not to eok as well.
Oct 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Jun 17, 2009 | Jandy Lite2 175,000 Btu Propane Gas...
Laars lite 2 pool heater burners will not ignite
millivolt readings are independent of pump and filter.just make sure heater is in off position for accurate read
Jun 17, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
1,020 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
