Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Power button stays red when you press it
Also there is no picture no sound but sounds like a transformer is making intermitent noise.
  • 1 more comment
  • johnschell74 Sep 13, 2008
    I checked for arching, there wasn't any arching anywhere. Do you have any other suggestions? Thanks.
  • johnschell74 Sep 14, 2008
    The tubes are not glowing at all.
  • gaynel Sep 21, 2008
    I have a Philips rear projection TV. When I turn on the TV the power light is red and there is a continuous clicking noise. There is no picture or sound.
    Novelist:
    Champion:
  • 203 Answers
Might be a bad tube or flyback transformer. Best thing to do is take the back off, turn down the lights, and stand behind it while someone turns it on. you may see one of the tubes arching or the flyback itself. Let me know if this helps or if you need more info.
Tim Nolan
Posted on Sep 12, 2008
  • experttv
    experttv Sep 13, 2008
    with the light out in the room, looking from the back of the set with the back off, are the bottoms of the tubes glowing yellow?
  • experttv
    experttv Sep 14, 2008
    How often do you hear this intermitant noise? Does the red light on the front stay on untill you turn it back off? Can you use a meter?
    Tim Nolna
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
Hello, I have an RCA standard definition television. Whenever I press the power button, instead of turning on the red power LED flashes (about 24 times) and then stays lit. There is no picture or sound,...
The High voltage Horizontal output transistor is dead.That the transistor sit outside of the wall of the FBT-flyback tranformer is a black block of plastic with a red wire with a cap hook to a CRT-(tv tube) U have soldering iron,a roll of solders and know basic electronic.The "H" trasistor replaced that and resolders the FBT-flyback transformer,should solved this problems.
Jan 29, 2011 | RCA TruFlat 27F520T 27" TV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
When I press the ON button it makes a weird sound and turns off
Ur hight voltage transformer is dead.It call a Flyback transformer,it the one with the big long red wire with the cap go to ur CRT(Ur tv tube).That thing is dead that where the noise came from.
Aug 23, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV pops, then no picture or sound
Trintitron were very state of the art when they came out in the 1960s. The Sony company stopped production of the newer version, flat screen in 2008 of the trintitron. Popping noises aren't a good sign. You can try resetting it to factory default settings. Try to have the power on to tv, then, hold down the reset button on the REMOTE CONTROL- next on the tv PRESS THE POWER BUTTON ON=IF AND WHEN THE TV WILL TURN ITSELF OFF AND ON AGAIN, THEN YOU CAN RELEASE THE RESET BUTTON. Unless it This noise is caused by the expansion and contraction of the cabinet during warm up and cool down of the lamp in the optical block of the television. This is normal operation. But you having no picture, this could be your power circuit is going out. You can get it fixed, but if it is an older tv you may want to upgrade to an LCD, HD, or even a plasma. They have really nice flat screen HD TV now that are not too expensive. But if you are pleased with this tv it might be worth getting it fixed.
Aug 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA 32V434T Changed recomended part: New Problem
Was the xformer RCA, new in the box ?.........
The silicon rubber seal is to moisture entry. Do not re-apply.
Make sure your connection is good.......
Did you hook-up signal to verify no sound ?
NSNP , HV ok = something wrong other than xformer....
Check all power supply voltages.....................T.
Check top of electrolytic caps for expanded,bulged or
what techs call "pooched".....................
Apr 17, 2008 | Televison & Video
No Picture, No Sound...Please Help
The most common problem this set has is the Horizontal Output shorting, usually caused by the High Voltage transformer drawing to much current. Whether it's the high voltage circuit or the power supply, having a tech look at this set would not be cost effective. Start looking at the newer technology. Hope this helped.
May 12, 2007 | Samsung TXN2771HF 27" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
