I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Seems
like you found out the hard way what I wrote about in this
tip...
Check it out it also contains some thing to try on how
to unlock that oven..
Self
Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I
never would have used the self cleaning option. Thanks for the info!!
" - amymrocks
