Question about LG Dryers
LG DRYER ERROR CODE "LEI" OR LE1" DRYER RUNS FOR A FEW MINUTES THEN DISPLAYS THIS CODE BUT IT IS AN INTERMITTENT PROBLEM. NEW BOARD HAS BEEN INSTALLED BUT DID NOT FIX THE PROBLEM. LG SERVICE TECH HAD NEVER HEARD OF THIS CODE OR PROBLEM. I VERIFIED PROPER VENTING. UNIT IS ELECTRIC. THANKS. EMAIL:bigsparkdm@yahoo.com
  • sparkydm Sep 13, 2008
    model # DLE5932w
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Can't say I've ever heard of this either. What is the model number of your LG dryer?
  • 1,543 Answers
Sorry it's taken so long to get back to you. I asked a LG factory service trainer your question yesterday at a factory service training meeting. He said that although there is not a code like that listed, he suspects you may have a bad neutral electrical connection. (I don't think the control itself is bad, because you replaced it and have the same problem. Not very likely you would just happen to get a replacement part which would be defective, esp. in the exact same way)
Start by checking the dryer cord connections to the dryer. Also check the wire connections inside the household dryer receptacle that you plug the cord into. If all good and tight, check the wires in the breaker box / fuse box, at the breaker and the neutral buss bar. Of course it is possible that there is a poor connection inside the dryer at a multi plug (make sure plugs all plugs you can find are seated firmly and wires are not loose in the back side of the plug - have seen this on occasion) or a pinched / partially cut wire. (usually much harder to find) Good luck.
Posted on Oct 08, 2008
I have a code of "LE1" on the display, from the description on the code sheet it means thermistor open, what does that mean and how can i fix it
its a temperature sensor connected to the heating element about the size of small button. Usually straight forward to replace. If you do take the back off and replace it (maybe 2 off) make sure the back is replaced before you switch the heater back on to test it.
Dec 10, 2013 | LG DLG3788W Gas Dryer
Samsung washing machine with a error code LE1, the door is locked and nothing works, any suggestions??
The same LE1 error can occur when there is liquid in the reservoir area in the drop pan. There is a small float sensor that will signal this error if there is enough water in this area to raise the float. Removing the water & drying the area with a sponge is a simple fix.
I discovered this trick from the serviceman who came to repair my machine after we suffered flood damage. The unit was fine, but there was enough flood water in the drop pan to raise the float and prevent a normal wash cycle. After the 5 minutes spent removing the rear access panel and drying it out it was working like a champ again!
Mar 31, 2012 | Samsung Washing Machines
Kenmore 110.6807 Dryer won't run properly. In diagnostic mode, everything checks out, Dryer runs and heats. Getting F2 error in normal and diagnostic modes. I disconnected P5 and checked the switches on...
One of the first things to do when a F2 error code appears is to perform a simple reset. To do this, turn the dryer off and disconnect power to the dryer. Wait 30 seconds to one minute, restore power and turn the dryer on. Choose a new dryer cycle and push "Start" to begin. If the error code does not return to the display, the reset was successful and no further action is necessary. Hope this helps.
Read more : http://www.ehow.com/info_12001824_kenmore-elite-dryer-troubleshooting-f2-error.html
Dec 06, 2010 | Kenmore Dryers
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
. I have a LG WD12126RD front load washer dryer
This is a heater error. The heater element is open and not working. This is usually the problem but it could be other things also. You need a service call from an LG tech.
Jan 11, 2010 | LG WD-12126RD Front Load Washer / Dryer
LE Error code
SOUNDS LIKE LOCKED ENGINE. SEVERAL DIFFERENT THINGS CAN CAUSE THIS ERROR CODE TO BE DISPLAYED.
1ST, USING THE WRONG SOAP WILL CAUSE THIS PROBLEM - USE HE SOAP ONLY!!! - IF YOU HAVE BEEN USING THE WRONG SOAP, BEFORE CALLING FOR SERVICE I WOULD ADVISE YOU TO RUN A FEW SHORT CYCLES WITH HOT WATER ONLY - THIS SHOULD HELP IN REMOVING ANY SOAP RESIDUE FROM THE SOAP SENSOR AND BOOT AREA.
2ND, THE CONTROL BOARD MAY BE DEFECTIVE - YOU NEED TO CHECK VOLTAGE OUTPUTS TO VERIFY.
3RD, BE SURE TO CHECK THE WIRING HARNESS - IT HAS BEEN KNOWN THAT WIRES SOMETIMES BECOME FRAYED AND LOOSE RESISTANCE.
4TH, THE SOAP SUDS SENSOR MAY BE FAULTY AND NEEDS TO BE REPLACED.
Regards
ami-man
Dec 04, 2009 | LG WM1812C Front Load Washer
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Kenmore 62602 Electric Dryer
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Dryers Logo
401 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
