Compaq Presario cm2070 cannot turn on
My aptop was okay and not used for about six months, now it won't turn on at all.
The charge light comes on but the battery light stays off.
I have replaced a brand new battery, and still no luck.
Can someone please help me?
  • ANNDEANS Jan 23, 2009
    I HAVE TWO CM2070 AND NONE WILL TURN ON JUST POWER LIGHT ON ON CHARGE LIGHT AT ALL MAIN BOARD ON THIS MODEL SEEMS TO HAVE A BUILT IN DESIGN FAULT. LOOKING FOR NEW M/BOARD NEW OR OLD ANNDEANS@SKY.COM.
Ensure that the battery is in date and charging. Also it is the right battery amp hours and so forth. It could also be your adapter has weakened over time and can't handle the load of charging as well as powering up your PC at the same time. These are just possibilities. See if the Business where you bought your battery can test your adapter. It also takes a fair amount of time to charge a battery from initial use. If they can't maybe Radio Shack can test it for you.
Head the Warnings if you don't know your way around a Volt meter it can be Dangerous.
Posted on Sep 12, 2008
Presario cq60-420 won't power on or charge
Is not necessarily a problem of the battery, the screen is also related to, a change in the LCD.This should help you http://www.lcdinverters.net/Laptop-Inverter/Compaq/Compaq.html
Oct 10, 2012 | Compaq Presario CQ60420US Pentium DualCore...
COMPAQ V2030US POWER ON WON'T START
if there are no Power light,you battery might be broken or your power button is broken,i suggest you to charge your battery or take it to notebook center (if charging still failed,it might be the button)
Aug 27, 2012 | HP Compaq Presario V2000 Notebook
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Power button problem in Compaq Presario Laptop V6307TU? I have a laptop - HP Compaq Presario V6307TU which, since a few months, starts automatically immediately after I shutdown or hibernate the laptop....
Windows corruption - either a driver is malformed or one of the Wake-up settings from the device or Power settings is wrong. Easiest way is to reinstall: use a generic XP install disk with your key and later get the drivers from the HP site.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3421162
Jun 29, 2011 | Compaq Presario Notebook
My compaq presario CQ61 only charges when the computer is turned off when i switch on the computer it stop charging.whats the solution for this
this is a regular problem with compaq presario cq?? series . There won't be any problem with the laptop. you will only have to change the adaptor.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | Compaq Presario Notebook
Been sitting for six months won" start
try your battery first most of the time thats the problem when you turn on your engine you should have lights if you dont then your battery is dead and that is the problem would reccomend you either charge the battery if that dosent work replace it but check first if lights are working a 6 month lie up would deaden your battery best of luck also any battery charger would do for the charge and also on a short term you can jump it from a car battery with the leads just to make sure its the battery also but do not try and charge from the car just check to make sure its the battery by doing this
Mar 16, 2011 | 2003 Honda CBR 600 RR
Back light will not turn on
please send the compaq presario laptops full drivers
Jan 21, 2009 | Compaq Presario M2000 Notebook
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
1,069 people viewed this question
David Payne
David Payne
