Question about HP PSC 1210 All-In-One InkJet Printer
Copy comes out all black
Whenever I try to copy an item, the output is a sheet of ALL black ink - the whole paper is black ink HELP!!!!
  • 7705anna Sep 11, 2008
    Why does my copy come out with the whole page in black ink???
I lost my hp psc 1200 all-in-one printer driver and pl send me install driver. my email id mahendersing08@gmail.com
Posted on Sep 14, 2008
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
When using the top loader to make copies, the copies come out with a line down the whole sheet?
I fixing is verry simple.Open the top cover of the copier(where you are putting the paper you want to copy).There should be two glasses(One big and one smaller wich is under the top loader).You need to clean the little glass from any dirt.Even a small peace of dirt can make a whole line on the paper,beacuse the scanner is not moving,but the paper is.So clean the little glass(wich is next to the big one and the line will be gona.replay if you need any futher help.Please vote if that was helpfull!!
Nov 09, 2010 | Canon PC-D340 Black and White Copier
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
The black ink in my Epson dx6000 won't work. I've wasted so much ink cleaning the print head. HELP!!! Please!!
You could try this Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Hope it works for you. Worked on my HPc6180
Apr 28, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
64 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
