Question about Linksys Wireless-G WRT54G Router
Cannot re-connect My computer runs straight off the router. My daughter, just got her computer back from being repaired and we cannot get it back up on the internet. Can you help!
  • Docdunit Sep 11, 2008
    Do you do this on the main computer where my router is or do you do it on the computer that we are trying to get the internet hooked back up on?
  • 3 Answers
Hold down the reset button behind the router for 10 seconds pull the power plug for another 10 seconds then plug it back in. Plug the ethernet cord directly to the computer/laptop from one of the router ports. On your internet explorer page type in 192.168.1.1 this will forward you to the router type admin on both boxes. Then check the settings on the security reset new password
Posted on Sep 11, 2008
I attempted to hardwire connect my xbox 360 to a Belkin router. When I tried to connect and went through tech support with router I had to change settings. After changing router setting with my computer,...
there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Dec 16, 2010 | Microsoft Xbox 360 Console
My problem is that on my daughters computer it says connected with limited access. yet on the main computer where the modum is placed the internet works fine. my daughter has claimed she did not do...
Hello
Try to reboot the router.
1 shut down all pcs connected to router.
2 Unplug all cables from router,mark them if you think you will forget.
3 Unplug power from router also.
4 In the back of the router there is a small reset button hold this in for 1 min with a pen tip or a paperclip.
5 Replug everything back into router,power up router.
6 restart your pcs.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
My daughter has a lynksys router wrt54g. it is connected to a cabe modem. The wireless works great, but wired compters won't connect to the internet.
Wired Connection
1. Check your hardware connection:
Make sure that you use a straight cable and not a cross over cable. And also make sure that the cable is not broken or loose.
2. Check your hardware devices:
If you are using a hub, modem, or router on your network, make sure that they are connected properly and switched on. Sometimes, the solution might be as simple as restarting the modem/router, then your computer. You can also try connecting the Ethernet cable to another port of the router to test.
3. Check your network adapter:
Disable and enable your Network Adapter to make sure that it is functioning.
4. Obtain IP address automatically:
If you have set static IP address on your computer previously, it could be one of the reasons of why you are unable to connect to the Internet. So, you should set your computer to obtain IP address automatically. If you are not sure how to do it, we have an article here to guide you.
Wireless Connection
1. Check your wireless key:
When you connect to the wireless connection, you will be prompted for wireless key (password). So, if you have entered an invalid key, you will not be able to connect to the Internet. Therefore, make sure that you have the correct wireless key. If you are not sure whether you have the correct key, ask the person who setup your wireless network for help. OR, click here to learn how to check the wireless settings on your router to find out your wireless key.
2. Repair your Internet connection:
If you are experiencing limited or no connectivity on wireless connection, click here to learn how to repair your Internet connection on Windows.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
Every time my daughter uses her laptop, my pc says
Either unplug the router from power source for 10 seconds and plug back in to reset.
Or you may have an ip address on the pc itself that is conflicting with your daughter's ip address. Dynamic ip address are set so they don't interfere with each other. We use 4 different pc's on one router in our home.
You can change the ip address of your computer by going to start menu, then run, then type ipconfig /release, then type ipconfig /renew and it will give you a new one.
Or you can access the software and settings of the router itself by opening up an internet page, go to address bar and type 192.168.1.1 and hit enter.
It should bring you inside your router so you can check and switch any settings.
Nov 17, 2009 | NetGear WGR614 Wireless Router
I was wondering how i can disable my internet connection without disturbing any function on my computer so I can easily go back and able the internet. Reason: I am trying to prevent my daughter to use the...
on your computer.
Click start then run then type in ncpa.cpl
Right clck on Local Area Connection and click disable if you are on the wired connection and Wirelss Network if you are on wireless. Then just reenable if you want to get online.
Jan 05, 2009 | Linksys Wireless-G Broadband Router
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
Please Help
How does your Daughter's computer connect? You state that yours connects directly, does here's connect via wireless connection? If so, then you'll merely need to view wireless connections with her PC and select your Linksys router and click on the connect button after which you should be prompted to enter your passkey/pass phrase to connect to your network. If you cannot remember the passkey, then do as suggested above and reset your router to default settings by pressing the reset button for 10 seconds or so while it's powered on and that should reset it to default with no security. Just make sure to enter the address 192.168.1.1 to address your router and re enable your security. I believe the default User Name is Liksys, and Password is Admin for your WRT54G Router.
Good luck.
Sep 12, 2008 | Linksys Wireless-G WRT54G Router
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
How to get a third computer to work on my wireless network
is the adapter connected to the router? are you using wep? is the firewall disabled?
Nov 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
