Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Panasonic PV-GS32 Problems with Playback
I have a Panasonic PV-GS32 that I have used approximately 5 times. The first few times I used it I had no problems recording and replaying videos of my son. Now when I try to watch what I have recorded the sound skips, the video gets digital blocks across the picture and it sounds like the heads are sticking. Someone told me to try a head cleaner and that didn't work. Any ideas on what could be wrong? How much it would be to fix it? Thanks
    President:
  • 3,130 Answers
Wit wait WAIT!!! isent this a mini dvd recorder??? I've seen a dirty lens cause this BUt if the lens is clean The problem could be in the cucuit BUT try cleaning first as described in your owners manual. Good LUCK
Posted on Apr 30, 2006
  • Larry  Dillon
    Larry Dillon Apr 30, 2006
    NEVER MIND!!!!! IM THINKING POORLY TODAY!!!!!
    Champion:
  • 277 Answers
Hi well... this can be a small capacitor blown or it could be the microprocessor and it will cost like a new CAM cant know without more details good luck
The video won't load onto my computer.
Connect with a firewire cable and use Windows Movie Maker.
May 16, 2011 | Panasonic PV-GS32 Mini DV Digital...
The battery won't take a charge can you buy a new one
Batteries are available at partstore.com, thats where i buy most of my repair parts. I hope this helps.
Sep 05, 2010 | Panasonic PV-GS32 Mini DV Digital...
During playback there are 5 horizontal blue lines that display. Can I fix this myself?
try with head cleaning cassette 2 or 3 times if problem presists change video head assembly
VEG1731
May 20, 2010 | Panasonic PV-GS150 Mini DV Digital...
Cannot capture video from Panasonic DV Camcorder
Check if ur firewire cable is this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Once connected,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
Dec 18, 2008 | Panasonic PV-GS32 Mini DV Digital...
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Camera and computer
Yes, depending on your system and software, you can use this as a webcam. I have listed the link for the owner's manual, instructions are on page 54.
Hope this helps.
PV-GS32 manual
Sep 10, 2008 | Panasonic NV-DS65 Mini DV Digital...
How to convert video from Panasonic PV-GS32 to DVD
It seems that the video you took by your Panasonic Camera is MOV format. I’m not so sure about that. If it is, you need to use software to convert the video. What I use is Aimersoft DVD Creator. I think you may find some help here:
http://www.aimersoft.com/dvd-creator.html
Oct 07, 2007 | Panasonic PV-GS32 Mini DV Digital...
Video playback is distorted and has no sound
Usually head cleaner tapes do not do much more than wear the heads out and move the dirt around or in some cases if it is an old tape it may add dirt to the system!!! Someone needs to remove the cassette cover and clean the video drum, tape path, pinch roller and capstan with denatured alcohol. Do not use anything but 100% alcohol as anything else will have contaminates in it. The video head pole pieces are extremely small (we're talking microns) and can be plugged easily. Cleaning the tape guides, audio heads, erase head, capstan and pinch roller is pretty straight forward and the same as any audio deck. Using a lint free Q-tip (or special head cleaning sticks from electronic stores) dip in alcohol and remove any dirt etc from the pieces. Cleaning the video drum is a little trickier. Using the same kind of cleaning stick dipped in alcohol, gently wipe around the video drum assembly. Never, ever go up and down across the face of the head or you could break the video heads!! If you do not know the proper way to do this you should take it to a qualified tech or you could do more damage than good. If you clean your unit the way that I described it should be fine. On occasion I have had a unit with a clogged head that requires a different technique to clean but you would not be able to do this. If cleaning does not work you will need to take it to a repair shop for service. Good luck.
Jun 10, 2006 | Panasonic PV-GS32 Mini DV Digital...
Panasonic PV-DV702 Garbled playback - any solutions??
Try a different tape. The tape itself may be bad.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
128 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
