WASHING MACHINE WILL NOT DRAIN
It runs fine in all cycles, but will not drain or spin water out.
  • 3 more comments
  • tomc121 Sep 11, 2008
    Maytag Dependable Care model LAT8624AAE serial AO291078MD
    The machine cuts off when the lid is lifted. Is that the lid switch you are refering to?
  • tomc121 Sep 12, 2008
    It does ok through the wash, rinse, and spin cycles - and will shut off when the lid is opened (any cycle) as well as just before the spin cycle begins. It sounds like it tries to drain (at the end of the rinse cycle) but it does't. There is a pause accompanied by a smell similar to a motor heating up, then the spin cycle begins with the tub still full of water. The machine will complete the spin cycle and shut down as directed by the timer. I have checked the drain hose and the drain into the house plumbing and found them both to be free of clogs or debris. Could it be a faulty drain pump? Maybe a filter somewhere is stopped up?
  • tomc121 Sep 19, 2008
    The hurricane has delayed my ability to answer, but thanks for this tip. I will follow through and let you know how it turns out as soon as possible.
  • sinead_mchug Apr 02, 2009
    We have the same problem with our washer, but lid switch does work, so wondering about whether you mean drain or motor as the culprit then, and since it runs through the entire cycle, except for the drain, I presume the drum or pump are not to blame? Our model is maybe an older one: Maytag LAT8624AAE.
  • 116 Answers
Hi tomc121
Your most likely culprit is a defective lid switch.
Regards
Posted on Sep 11, 2008
  • D Clare Sep 12, 2008
    Your machine carries a check switch - as well as a lid switch. The check switch stops the wash cycle but the spin works through the lid switch
    Regards
    You said
    "There is a pause accompanied by a smell similar to a motor heating up,
    then the spin cycle begins with the tub still full of water" Did not realize that it was attempting to turn
    This sound like the motor is attempting to turn but is over heating and tripping the overload (hence the pause). You may be having a failing motor. The drain is not independent of the spin cycle - the motor turns both the drum and drain pump simultaneously through belts. doubt a bad pump - usually leaks if bad.
    Regards
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Whirlpool washing machine not draining.
Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
Oct 07, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
