Question about Broan-NuTone VX475 Bagged Central System Vacuum
Nutone central vac vx550
The vacuum cuts out after a few minutes on.
  • Anonymous Mar 27, 2014
    After speeding up and stopping it will not start again. The display is still on and seems to not have changed. I pressed the start button with not response.
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Posted on Sep 12, 2008
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
Motor quits after about five minutes of use . I have a VX600C , no bag thanks in advance MIKE
heat sensor on the motor its bad thats why it shuts off or your relay module is bad
Feb 19, 2011 | Broan-NuTone VX550 Bagged Central System...
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
Vaccum runs for 2 or 3 minutes then shuts off. Can not restart it for several hours. We have tried EVERYTHING with no luck. I see there is the same problem with the VX550...is there a recall on this one...
The VX series NuTone's have had some problems but NuTone is taking care of them as long as it is under warranty. You can contact NuTone at 1-888-336-6151 or whoever you purchased the unit from and you will most likely get a new unit. There are no parts available for the VX units so whenever there is a problem NuTone has been sending new units out.
Oct 06, 2009 | Broan-NuTone VX475 Bagged Central System...
Vx550 issues
Heven't fixed it yet, but I've pulled the motor to see what the specific issue is. As soon as I have the problem isolated and a solution, if possible, I'll post it here. I will have to contact Nutone Monday and see what they will do. If nothing, I'll sort it myself.
Tiny
Oct 02, 2009 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
Mar 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
646 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
