Question about Compaq Armada M700 Notebook
162-System options not set
When I start up my computer it says 162-options not set, what do i do?
  • reiverof Mar 27, 2009
    162 system is my problem its **** everytime i open my laptop!! plz.. give a solution to solve my problem with this system they call 162....???
  • Compaq Master
  • 5,568 Answers
I tried to find how old that model is but had no luck; this message may mean that the CMOS backup battery, normally a small 'coin' cell, needs replacement. That message says that it can't remember who and what it is and that happens when the battery is depleted. Check you user guide about replacement of that battery; it should be a DIY job. The battery will cost <$10 US even if you stumble across a crook selling them. Wholesale, they are about 20-30 cents.
Posted on Sep 11, 2008
I had same problem ,when i pulled off the cmos battery for 5 min and then put it back and switched on the laptop ,it was ok and there was no problem and it worked ok.
Asif malik
Posted on Mar 14, 2009
5 Suggested Answers
dmathwizard
  • 113 Answers
SOURCE: no booting
This error means your bios is corrupt. The first step is to replace the CR2032 battery inside the computer. Upon reboot choose fail safe settings in the bios. The bios can usually be accessed with either F2, F9, F11, or the delete key.
If this does not solve your problem then you are left with options to listen to it until windows boots or replace your motherboard.
Posted on Mar 01, 2008
duployen
  • 32 Answers
SOURCE: 101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
Posted on Jun 08, 2009
SOURCE: 162-System Options Not Set; 163-Time & Date Not Set
I DO IT BUT IT STILL BE THE SAME
Posted on Feb 23, 2010
  • 5 Answers
SOURCE: my computer once i switch
replace cmos battery with usual CR2032- works fine. E-mail any questions to fizmat@rambler.ru
Posted on Mar 27, 2011
System options not set hp compaq dc 7600
Make sure your clear cmos jumper is not in the clear position! It is usually close to the battery and there is labelling on the mboard near it. If you're sure you didn't move it, then don't worry about that.Did you try setting the bios to defaults?
One possibility - it could be it does this if you don't re-set at least the date (and possibly the time) in the bios from the default it sets itself to when you remove the battery or use clear cmos - set it to today's date and time, or to anything other than the default, save settings.
If after you save the above settings, turn off the computer for a few minutes, and check the bios again, the date and time re-sets to defaults, then the cmos doesn't see the battery. If the date and time are consistant with what you set them to, it is seeing the battery.
By the way, I don't think this is the problem because you have the 162 error code, but make sure the battery polarity is right - is in the holder the right way - and the contacts for it are making good contact - if it is the wrong way or the contacts are poor, the cmos will think there is no battery. Usually you can tell by the way the contacts are arranged which way it goes - if it is the wrong way both contacts touch the same part of the coin cell (if that is what you have) - usually + is upwards.
If setting the bios to defaults, setting the date (to anything other than the default) does not get rid of the error message, try making sure everything on the board is properly seated. Unplug the computer when you do that!
.........it says memory error, below that it says 162 System Options not set, then it says 164 error.
(later)
I just took everything that would unplug and reset them in and it corrected the problem. Thanks
That error code is common on many computers, and in many bioses.
e.g.
161 POST Error - System options not set - (Run SETUP) - battery
162 POST Error - System options not set - (Run SETUP)
161 System options not set; dead battery
162 System options not set; CMOS checksum/configuration error
If it is 161 the battery is dead, it is installed with the polarity backwards, or the battery contacts are not making good contact.
If it is 162, there is nothing wrong with the battery - you need to go into the bios Setup.
I have found nothing other than the above post about what to do about that.
If you still have issues, go to and talk to one of our techs
Clean Optimize Speed Up and Secure PC Freeware Download EZ System Repairs
Oct 15, 2015 | HP Compaq dc7600 Small Form Factor PC...
I can't get a connection
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
?? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this. ?? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database. ?? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz. ?? Open Internet Explorer; ?? Click on 'Tools'; ?? Click on 'Internet Options'; ?? Click on 'Connections'; ?? Click on 'Setup' ?? Click on 'I want to set up my Internet connections manually . . .'; ?? Click on 'Next'; ?? Click on 'I connect through a local area network (LAN); ?? Clock on 'Next' ?? Click on 'Next' [This is not an error]; ?? Click on 'No'; ?? Click on 'Next'; ?? Click on 'To connect to the Internet immediately . . .; and, ?? Click on 'Finish'.
That should have you online. However, if it doesn't get you connected, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might have more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
Clicking the Start button Picture of the Start button • Click on Control Panel. • In the search box, type network, • Click "Network and Sharing Center" • Click Set up a new connection or network • Then double-click "Connect to the Internet".
All the best
Ben
Jun 28, 2011 | Sylvania G-Netbook
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
I have a password problem on my laptop,but not window password it board password please help my out.
If you are talking about the password that is just ask when the comp starts....You can try this...
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a â 162 System Options
not setâ message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
May 06, 2011 | HP Pavilion dv6000z 15.4" Notebook Laptop...
"162 system options not set"
Before you spend money, try pressing the key it prompts you for to enter the BIOS and look for an option to set the configuration to safe / default settings (its usually in the right most tab with the save / quit). Try selecting that, saving and quitting. This sometimes can get you past BIOS errors. Worth a shot compared to the hassle of swapping out the board.
Hope this helps.
Apr 07, 2011 | HP System Board AMD Micro BTX With AM2...
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
It plays movies for me, but not the games.
If still on warranty, use your warranty :)
If not try to do what i did.
I had exactly the same problem. I managed to fix it by executing so called Rebuild Database operation.
I followed these instructions;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Jun 08, 2009 | Compaq Armada M700 Notebook
The bios settings are being lost during offtime. This is due to the cmos battery being dead. Most units have a round 3-volt lithium battery in a clip/holder. A few use a rechargeable battery that recovers if the unit sees frequent use. Can you verify the model number of this unit?
Jun 02, 2009 | Compaq Armada 1500C Notebook
Compaq Armada M700 Notebook Logo
1,018 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
