APC Smart-UPS VT 20kVA (SUVT20KF3B4S) UPS System Logo
Posted on Sep 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dear Sir, Please find below the requested information. Model Number: SVTPF20KB2H S/N : PS0919240477 Version: Rev 4.5 System Location : Kabul ,afghanistan in one hospital. In Dig.page we have the following err 1. Replace Battery 2.Weak batt.Detected ,reduce running time. The same time we have the red LED on. I need to run the system normal without any err. The batteries are new . Would you Please send me the Service Manual too. I am waiting for your instruction. [email protected]
Gruber Power Services
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 176 Answers
  • Posted on Sep 08, 2011
Expert
Level 2:
Mentor:
Answers
176
Questions
Helped
95513
Points
221
You get this one for Free
2answers
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
2helpful
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
2helpful
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
1helpful
I am looking for the Sky remote code for a Sony KDL-40V2000 TV can you please help.
Sky don't have a specific code listed for this model yet, so the first thing to do is try the Generic Sony codes first. These are:
1679, 1533, 0678, 0681
These codes are for a "Rev 8" Sky remote. If the above codes don't work or you need further assistance, please post back and I will investigate further. When posting back, please state which Sky remote version you have and whether it is also Standard Sky, Sky+ or Sky HD. The version number can be found on a sticker inside the battery compartment. RC1600/00 is the old original. Newer remotes will also have either "Rev 4", "Rev 6" or "Rev 8" on the sticker.
Please note that Sky remotes wont work with all TVs. I've been informed that a new revision of the Sky remote is due soon but I have been unable to verify this.
Hope this helps. Please post back with the information requested above if you need further assistance.
Regards,
BElectric
2answers
4helpful
2answers
No display on my intel motherboard
click here , to go to intel india's replacemnt and warranty webstie... go through the rules , then enter yuor model number and the serial number... u have to courier it to intel .. then they will replace it and send it back to you in a month (Maximum) Plz rate my answer...
Microcode Patch Error,Where to download Bios Free
What model compaq?
Have you tried HP.com ? If OEM they will have the driver. If not I use driverguide.com for drivers I can't find. mysleuth
http://search.hp.com/query.html?lang=en&search=++&qt=Intel+Solano+i815&la=en&cc=us&charset=utf-8
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
1helpful
MY CAR SOUND SYSTEM REQUESTING FOR CODE NUMBER.
call an autorized MB dealer and they have the codes you need..may have to give them VIN
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
