Question about Electrolux EOU6330 Electric Double Oven
EOU6330 grill doesn't heat-up all the time.
I have an Electrolux EOU6330 double oven/grill. The grill has started to take a long time to heat-up and also grill the food. Sometimes it ok, other times it takes like 20 minutes to warm-up.
Can anybody help please.
    Genius:
  • 1,239 Answers
Hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Posted on Sep 12, 2008
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Is it possible to turn light off and oven still heat up?
I think that is normal. It is wired into the element voltage. I suppose you could unscrew the globe, but why bother?
Dec 01, 2011 | Electrolux EOU6330 Electric Double Oven
My oven light turns on but the oven doesnt heat up
If it is a fan assisted oven, and the fan is working o/k, then it is likely to be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Dec 17, 2010 | Electrolux EOU6330 Electric Double Oven
Bottom oven not heating
if the light and the fan in the oven is running then the element round the fan is faulty. the lower oven runs through the timer check you have the time of day set.
Aug 06, 2010 | Electrolux EOU6330 Electric Double Oven
I have an electrolux EOU 6330 double oven, how do I gain access to change a faulty element?
Assuming you live in the u/k, and it is an electric fan assisted oven, and that it is the fan oven you are referring to, then the element is usually to be found at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 10, 2009 | Electrolux EOU6330 Electric Double Oven
Bottom oven not working have put new element in still not heating
You need to determine that you are getting power to the element, you will need a meter to test with.
If no power, then could be faulty thermostat or regulator switch.
If you have power, then element faulty.
trust this helps you.
Thanks.
Dec 05, 2009 | Electrolux EOU6330 Electric Double Oven
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Electrolux EOU6330 Electric Double Oven Logo
272 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
