Question about Cameras
I have a cracked LCD display on my HP R967 camera. Can this be fixed?
  • 25 Answers
This can be fixed. but the real question you want to ask yourself is is it worth it to be fixed. based on retail value of the r967 it would be alot cheaper to buy another one as opposed to spending on parts and expensive labor. it's certainly fixable...but you'll save time and money by getting a brand new one.
Posted on Sep 11, 2008
Why wont my HP photosmart R967 turn on battery is new and docking station is fine but it will turn on if connected to docking station
It is likely the battery is not making contact properly or is not getting fully charged.
Check the instructions on battery connection on page 9 and confirm the lights are blinking correctly to show battery is charging.
http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Aug 03, 2014 | HP Photosmart R967 10MP Digital Camera,...
My R967 got a little moisture on my last fishing trip to canada, so I took the battery out and memory card and blew it with a blow dryer, it had blue stips in the monitor and I kept it on the charger for a...
actually the moisture must have entered the leads of the display...
the leads should be removed and then it should be dried so take the moisture off..
better take it to a service centre..it is risk to manually operate the sensitive parts inside and you could end up damaging the display
Jun 26, 2008 | Cameras
Spots in the photos (HP Photosmart R967)
Do you see it on the screen as well as on the computer? Then there is something in the camera; dust or debris, and it needs a cleaning. If it is just on the camera screen, there could be a defect on the LCD.
Apr 14, 2014 | Cameras
How do I download pictures from my photosmart R967 camera?
Download & read the User manual photosmart R967 camera instructions @ http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Hope it helps.
Mar 30, 2011 | Cameras
Looking for 2 GB memory card for HP camera- R967
The R967 uses standard SD cards. You should be able to purchase them at any department, electronics, or office-supply store. You may also see them at many drugstores and supermarkets.
Dec 15, 2010 | HP R967 Digital Camera
Our daughters HP photosmart M637 camera's display looks like broken glass. She says she did not drop the camera but was scroling through her photos and all of a sudden the display window went blank and...
As you suspect, this simply does not happen unless the LCD panel has had a physical impact. The LCD units are stress tested when manufactured and the odd ones which crack "all of a sudden" would do so within a few months of manufacture and then get replaced under manufacturer's warranty. The broken glass which you see is the cracked LCD unit and it's behind an outer plastic protective cover.
The only way to fix it is to replace the LCD panel, but it's not a DIY job and repairs will cost more than the camera is worth. The M637 will only be about two years old but it was a budget model to start with so it would be cheaper to buy a fully functional used equivalent camera. There are even brand new models of similar or better specification which will be cheaper than a repair.
If the camera works "as is" then it may be better to put up with the fault until the camera no longer works.
Dec 07, 2009 | HP Photosmart M637 digital camera (L2455A)
Will an SDHC card work in the HP photosmart R927?
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
Sep 29, 2009 | HP Photosmart R927 Digital Camera
Card locked on camera
Hi there, to fix this, do this:
Remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 27, 2009 | HP Cameras
Hp r507 digital camera 1.5 lcd display cracked need replacement
I have been searching for nearly six months for replacement parts for several point and shoot digital cameras with no luck at all. I think the factory updates them so often it is not cost effective to maintain parts for them.
Aug 02, 2008 | HP Photosmart R507 Digital Camera
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
