Question about Canon PIXMA® MP530 All-In-One Printer
Phaser 6110 - red light on, not printing
Red status light is on, inks are full, no paper jam, front cover and rear covers closed. Tried Xerox telephone customer support - useless , "somneone will call you back" and on line help/form - also useless - no one ever comes back. This is our business's main printer - if we cannnot fix it within the next 24 hours I'm going to purchase an HP......
  • Anonymous Oct 26, 2008
    Got the same problem! Red light is permanently on but for apparently no reason. Troubleshhoting uide with m/c is waste of time!
  • Anonymous Jan 06, 2009
    I have the exact same problem. I take it no-one has any answers...
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Posted on Feb 05, 2009
Wrong cartridge
Posted on Sep 19, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red in xerox 6110
check the waste toner (it's on the left side of drum unit when you open the front cover) cartridge or paper jam if blinking!
Dec 04, 2009 | Xerox Phaser 6110 Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
A red light all the time on xerox phaser 6110.
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
Jan 24, 2009 | Xerox Phaser 6110 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
STATES THAT TO CLOSE TOP COVER TO CONTINUE
1. The top cover hinges are not connected to the ink slider bar properly. - Open the top cover and snap the hinge arms back into place and close the top cover. Check for proper operation. 2. Customer has not loaded the ink sticks properly and the top cover will not close properly. - Verify the ink sticks are loaded properly and that the customer is using proper Phaser 860 ink sticks. Close the top cover and check for proper operation. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 200469000 1 COVER; TOP COVER
May 22, 2008 | Xerox Phaser 8200 Laser Printer
Canon PIXMA® MP530 All-In-One Printer Logo
592 people viewed this question
old marine
old marine
