Question about Hunter Sontera 52" Ceiling Fan with 3-Light Fixture and Remote
Ceiling fan 7 yr.old ceiling fan suddenly does not work. Lights work; fan motor only hums but does not turn blades. Blades will turn manually so they are not stuck. No dimmer is attached. Manual says unit is self-oiling. Is there anything I can do other than buy new fan?
  • 2 more comments
  • Anonymous Jan 27, 2009
    I have a model #25736 that the light and fan will not turn on -- the red light onthe remote does turn red.
  • Anonymous Mar 01, 2009
    cassablanca fan will not turn, trys and mover 1/2 inch and stops, but the light kit works, is it the wall switch, or the fan
  • Anonymous Mar 12, 2014
    It is a large 5 blade fan,& i need 1 blade for it!
  • Anonymous Mar 17, 2014
    motor just buzzes but will run if you manually spin fan to get started,i have tried using 3n1 oil and it helped temporarily.
Check the brush connection between brushes and axle I.E. shaft that hold unit to ceiling, my unit needs brushes, will call Co. on Monday.
Posted on Nov 25, 2011
  • 3 Answers
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Posted on Dec 28, 2008
    ANTHONY PALISCHAK Oct 06, 2014
    That is the problem I have with my Fandelier Fan, Thanks
  • 3,130 Answers
There is a run capacitor inside the motor thats probably bad but 99% of the time its just not worth fixing these things unless you really like the style and color. Good Luck
Posted on Apr 27, 2006
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
Motor Humming but blades not running
Hi m.. if this is a new installation, look up at the area where the blades attach and be sure that you have removed all the black rubber packing stops. If this has been running and now does not , then you probably have a bad capacitor on the motor.
May 02, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
I just installed my ceiling fan with lights. The
Do the blades spin freely? If not, something may have fallen into the motor, jamming the blades. That would cause this. Also, make sure there is a good connection at the wire that feeds power to the fan motor (usually black, blue is the light) Good luck.
Mar 25, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Nov 18, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Hunter Sontera 52" Ceiling Fan with 3-Light Fixture and Remote Logo
758 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
