Question about Fuji FinePix S700 Digital Camera
Fuji Finepix S700
My pictures that I have taken do not show up on the LCD monitor when I try to review them. The screen is black. I can review them from the viewfinder only. What can I do to correct this?
Does the LCD monitor work when taking a picture? if not press the evf/lcd button to toggle between the viewfinder and the LCD screen
Posted on Oct 06, 2008
After taking a picture it doesn't show up on the memory card. tried a new card and new batteries. still same problem
Can you see the picture on the camera in review mode? If so, your internal memory is the culprit. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions.
Oct 23, 2010 | Fuji FinePix S700 Digital Camera
Display works when you look at pictures taken but not in picture taking mode. you can still take pictures looking through the view finder but the lcd screen in dark.
This does not seem to be an issue.
Try this one:
Go to setup menu by pressing F button situated behind your camera. select the setup menu and go to LCD option put the LCD on. now check if it works the way you want
Oct 08, 2010 | Fuji FinePix S700 Digital Camera
Fuji camera screen does not display picture even when screen is turned on when taking picture. but screen shows picture when you view pictures already taken
Hi dear, you need to see the manual (http://www.retrevo.com/support/FujiFilm-S700-Digital-Cameras-manual/id/2488ag805/t/2/)
Some camera only use viewfinder to shoot photo,The LCD is for setup and display photo only.Because it's off it will save a lot of battery power so that you can shoot more photos.Check it out in the manual.Have FUN!
Jan 21, 2010 | Fuji FinePix S700 Digital Camera
My fuji finepix s700 digital camera green power light come on but the screen is black
I apologize, but did you check to see if the elexctronic viewfinder is active instead of the LCD screen? There is a switch to the right of the viewfinder labelled EVF/LCD and if you accidently pressed that then the LCD stays dark until that is pressed again when the camera is on.
Jan 18, 2010 | Fuji FinePix S700 Digital Camera
Black/white
on the Finepix S700...on the back where the the LCD screen is you have the menu button with the four arrows around it. above the arrows you have the review button on the left and a silver button with an "f" on it. Hold the "f" button down for a few seconds and change it back to color. you have a few options so you may want to read what they are.
Sep 09, 2009 | Fuji FinePix S700 Digital Camera
Black-n-purple viewing screen my fuji s700 (s7000) camera
Sounds like a bad LCD as I had a similar experience with a different brand. The part itself is probably not very cheap... but if you have $120 you could get the same camera, referbished.
http://shopfujifilm.com/detail/FUJ+15747988R
May 03, 2009 | Cameras
My fujifilm s700 takes pictures but the lcd screen is busted.. you can see the pictures and screen through the eye piece.. but thats it. What should i do?
The only thing you can do is take or send the camera to an AUTHORIZED service center for replacement of the LCD screen. If you can live with just using the viewfinder, like in the old days, the LCD being broken should not effect the camera operation. Set the selection to the EVF (electronic view finder) position and this will stop the LCD screen from coming on. If this has helped, please rate it accordingly. Thanks and good luck. (BTW: I LOVE my Fuji S700)
Apr 29, 2009 | Fuji FinePix S7000 Digital Camera
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Sep 21, 2008 | Fuji FinePix S700 Digital Camera
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Oct 15, 2006 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S700 Digital Camera Logo
241 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
